Question about Indesit W 123 Front Load Washer
Iwde12 indesit, not selecting programmes not releasing water, not drying
Posted by savy347 on
Anonymous
    New Friend:
Hi, I have an indesit IWDE12, I programme the washer which then starts to spin with no water, after 2-3 mins the rinse light, the clock light and the door lock light start to flash and tha washing stops. Does anyone know what this problem could be?
Posted on Jul 28, 2010
  • rogo_vik
    rogo_vik Jan 11, 2011
    Possible mode of the laundry is enclosed on your machine with starch or paint. Install manually following mode.
How can I just use the 'express wash' part of the 'express wash & dry' programme without it going onto the dryer part on my IWDC 1605 ?
Surely the machine programming must have a wash and spin "only", without dry program setting or selection? OR check through the programming where to deselect the drying process.
Jul 25, 2014 | Indesit Washing Machines
Washing machine selecting programme door lockibg but not getting water checked pipes and water supply okay
Hi.Are there any error codes, ie lights flashig if so what are they.Or could be a faulty water valve coil if its an older machine.Need more info and model number.
Regards Elect App
Jul 13, 2011 | Indesit Washing Machines
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
Machine wont stop washing on programme 9! went for days. Had the error lights flashing but that stopped.
If you select a rinse and spin programme and it completes the cycle, then I would say that the heater element is probably faulty, because the programme will not advance until the water has reached the correct temperature.
If it does not complete the rinse and spin cycle, then it is likely to be the control module that is the problem.
Feb 09, 2010 | Indesit W 123 Front Load Washer
How to cancel drying?
Please press the reset switch which should be on the control panel or next to the loading door
Nov 14, 2009 | Indesit WA 115 Front Load Washer
Indesit WIDL126UK that never wants to stop!
did you ever get to the root of the problem >}?
mine is doing the same.
[email protected]
Sep 25, 2009 | Washing Machines
Shortly after turning my indesit idl530 on a fault code appears
the problem you are getting is a f01 fault,this is water in the base part of the antiflood devise.to check this if you tip the appliance backwards and water comes from the back at the bottom this is the problem,if you do this till it stops and then leave for approx 24hrs to dry out any water that may have gone on to motor,then check by switching on to start a program,if appears to work ok but then goes back to the same fault(draining all the time and light flashing)you will have to remove base and check for leaks.
Jul 04, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
Indesit D61D tripping RCD
the heater is faulty(shorted) and check that the hot water is getting to the appliance as the buzzing is the soliniod being powered but the water is not passing through
Aug 15, 2006 | Maytag 24 in. MDB8600AW Jetclean II...
Indesit W 123 Front Load Washer Logo
1,122 people viewed this question
Top Indesit Washing Machines Experts
peter gittos
peter gittos
Marvin
Marvin
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
