Question about HP LASERJET P1006 Printer
Firmware Download Error. The printer was unable to communicate with your computer. Please power cycle the printer, check the connection, and try again."
Posted by it85 on
Brandan Heasley
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
I did not know the LaserJet P1006 had upgradable Firmware. I know the newer ones do, but not the LaserJet P1006
Posted on May 31, 2019
1 Related Answer
ikkenom
  • 10406 Answers
SOURCE: The error message reads:
Turn the printer off.
Turn your computer off.
Check the "data" cable at both ends (printer & computer).
Turn the computer on, and let it fully load Windows.
Turn the printer on.
Try to access the printer.
Posted on Nov 25, 2009
My 5250 printer cannot load paper properly. It loads unevenly and displays error messages 3424, 3618, or lately 3520. I tried to upload new firmware, but no new firmware is available.
Hi there.
The error 3520 requires a firmware upgrade. Please click on this link for the firmware update.
Installation Instructions:
  1. Verify that the KODAK All-in-One Printer Home Center Software is installed and can communicate with your printer.
  2. Download the firmware file to your computer.
  3. Double-click the *.exe file, then follow the on-screen instructions. Wait for "Update complete! You may now use your Kodak Printer." to appear on your computer.
  4. Click OK to complete the firmware installation.
If your using a Mac, please click on this link.
Let me know if you need further assistance.
Thank you!
Aug 10, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error 79;04 comes up saying the power is off. We have tried turning the power off for several minutes but when we put it back on have the same problem.
Unplug any USB or network cables from the printer and try to power cycle. This error indicates a problem with the firmware on the printer and if it restarts without any cables attached there is a chance that you will be able to download the newest firmware to the printer. If it restarts, clear any print jobs from the queue and then reconnect the communication cable. Then down load the current firmware from HP and install it. This should solve the problem.
Jun 21, 2011 | HP DesignJet 500 InkJet Printer
900 Firmware error on lexmark x544 what does this mean
Within your printer there is a micro-processor and a memory chip. The Firmware is a piece of software that is loaded to a memory chip.
Error of the software has occurred, you therefore may need to flash the firmware of the printer.
Find the Firmware on the Lexmark website, be sure to get the EXACT one for your printer.
Remember a failed attempt will render your printer useless, contact a professional to flash the fimware if you are unsure.
Thanking you
damnor01
Apr 14, 2011 | Lexmark X544dn All-In-One Laser Printer
How to solve Firmware Download error on P1005
when i try to print by hp laser jet p1005 the red led is flashing then error appear (firmware download error) the printer was unable to communicate with your computer
what can i do to solve this problem
Mar 08, 2011 | HP Hewlett Packard LaserJet P1005 Printer
How do i download firmware for a 900 firmware error - lexmark 540n
Before you download firmware, the 900 error usually indicates a software or communications problem. Please try to do the following.
Disconnect every cable, except for the power cord and turn off the printer for 30 seconds or more to clear its memory
  • Clear all jobs in print queue then turn on the printer and see if the error returns
  • If the error does not return, try to print a test page from the Test Menu
  • If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
  • If the
Jan 17, 2011 | Lexmark Optra T620 Laser Printer
The error message reads: "Firmware Download Error. The printer was unable to communicate with your computer. Please power cycle the printer, check the connection, and try again."
Nov 25, 2009 | HP LASERJET P1006 Printer
Error code 55.0
Hi dcarlson580:
Here is your problem.
55.xx PRINTER ERROR
alternates with
CYCLE POWER TO CONTINUE
An internal communications error occurred.
The page containing the error will automatically be reprinted.
1. Check the power at the printer location.
2. Replace the formatter and/or firmware DIMM.
4. Replace the engine controller board
Hope this helps
Jun 30, 2009 | HP LaserJet 4100 Printer
49.00F service error
From the service manual:
A critical firmware error has occurred that caused the processor on the formatter to abort the operation.
This type of error can be caused by invalid print commands, corrupt data, or invalid operations.
In some instances, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or specific software programs.
Sometimes, the formatter itself is at fault, which is usually indicated by a 79 Service Error.
Recommended action:
1 Press CANCEL JOB to clear the print job from the printer memory.
2 Turn the printer off and then on.
3 Go to www.hp.com/go/lj4300_software, Select Download Drivers and Software. Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the one installed on the printer and the printer can receive a firmware update, download the newer firmware
upgrade. Not all HP LaserJet 4200/4300 printers can receive firmware upgrades.
4 Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
5 If the message persists when using different software programs and attempting specific print jobs,
disconnect all cables that connect the printer to the network or a computer.
6 Turn the printer off.
7 Remove all memory DIMMs or thirdparty DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
8 Remove all of the EIO devices from the printer.
After performing the actions above, procede with the following:
1 Turn the printer on.
2 If the error message disappears, reinstall each DIMM and EIO device individually, making sure to turn the printer power off and then on again as you install each device.
3 Replace the DIMM or EIO device that caused the error message.
4 Remember to reconnect all of the cables that connect the printer to the network or computer.
5 If this error message persists, replace the firmware DIMM.
6 Replace the formatter assembly.
Jun 16, 2009 | HP LaserJet 4300dtn Printer
Panasonic FP-7735 error E7-01
E701 is reported when the controller is unable to communicate with the IOT(image output terminal).The following check might save some further troubles.
1.If the the controller is pretag 2,connect a terminator to the SCSI port marked "HOST"
2.Disconnect the IOT,power up the controller,press the reset switch on the controller board and allow reset cycle to complete,power down,reconnect,insert floppy firmware,power up.
3.Down grade to firmware 2.7
4.Check PSU +5V and +12V at the pcb.
5.Check HD drive present on the config printout.
6.Check reset switch if not stuck in on controller.
7.Check controller to IOT cable in good condition.
8.Replaced the flash SIMMs
And lastly if all the above fail to cure the fault then replaced the controller board.
Jan 03, 2008 | Panasonic FP-7735 Black and White Copier
Unable to communicate error
I have to make some assumptions here, let me know if I'm wrong. I assume you're using Windows Xp (Pro or Home). If so, disconnect the printer from the computer. Go to the Control Panel/Add Remove Programs. Uninstall the Dell printer. Go to the Control Panel/Printers and Faxes On Menu bar, click on File come down to Server Properties. in box that pops up click on Drivers/ Click on the Dell printer, click on Remove. Go to: http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PRN_INKJET_720&os=WW1&osl=en&catid=&impid= Download the latest driver for your Operating System to a location on your computer so that you know where to find it. Reboot your computer. Go to the downloaded driver. Double click on it. Follow the directions on the screen. It will let you know when you need to connect the printer to the computer again. That SHOULD do it. If it does not, please let me know before you rate this solution. I will try to provide additional information. Ed
Jun 28, 2007 | Dell Inkjet 720 Printer
HP LASERJET P1006 Printer Logo
864 people viewed this question
Ekse
efs_perpends
efs_perpends
