Question about Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue
I plug my vacuum in and turn it on and nothing happens. checked different outlets and still the same problem.
Posted by midevil1981 on
BISSELLcsr
  • 276 Answers
Check the following:
- The handle may not be installed properly, causing a loss in the power connection. Remove the handle completely. Slide the handle back into place on the lower section of handle and tighten the screw.
Posted on Jun 15, 2010
1 Related Answer
askdyson
AskDyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: Dyson DC07 Animal will not turn on.
    Hi Thomas,
    I'm sorry to hear you're having difficulties with your DC07. Your issue sounds unusual, and we'd like to run through some troubleshooting checks over the phone with you. Once we've identified the cause of the issue, we'll be able to provide further assistance and advice.
    You can call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Dyson Online Customer Support
    Posted on Dec 14, 2011
    When i plug it in it has no power. how do i fix this?
    -Just happened...? It work before...?
    If yes then try difference outlet. Still not work than
    possibly bad switch. Check it out and fix it.
    Good luck
    mai
    May 29, 2016 | Euro-Pro EP923 Canister Steam Vacuum
    Lately as I'm vacuuming, my vacuum will turn off. I can start it again, and it will shut off again. It seems like a power issue. Happens different places in the home, so it is not the outlet.
    Some vacs shut off when the dirt bag is full Check your brush area and see if there is dirt or bits of string like things wrapped around the brush or the brush ends. This will cause the machine to shut down as well if there is pressure holding the brushes. Will it run if you wiggle the plug if so you could have a bad plug as well.
    Jul 07, 2015 | Kenmore Vacuums
    Hi Thomas,
    Kind regards,
    Jack
    Dec 10, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    I plugged in my spotlifter and nothing happens. I
    Please check to ensure the power cord is not damaged and the CID has been reset. For futher information about this call us when you are with your machine at 1-800-237-7691, Monday - Friday 8 a.m. to 10 p.m., or Saturday 9 a.m. to 8 p.m., ET. A representative will assist you.
    Jul 04, 2010 | Bissell SpotLifter 1716 Bagless Handheld...
    Vacuum is not turning on
    Try a ruling out a couple of things first before opening up the handle:
    1) First lets make sure your outlet has power
    a) can you plug anything else in and have it work?
    b) is the vacuum plugged into a non-switched outlet?
    c) will the vacuum work from a different outlet - in a different room?
    2) Check the plug. Are the prongs loose? If so, you'll need to cut the
    plug off, splice back the two wires (Black and White), then connect
    to a new plug. You can get a new plug for $1-2.00 at any hardware
    store.
    3) Time to open up the handle:
    a) sometimes the wires connected to the switch can become loose
    and fall off. if that is the case just reconnect by plugging them
    back onto the switch. You may also consider using pliers to
    compress the connector onto the switch terminal.
    Hope this helps!
    Jul 05, 2009 | Oreck XL Ultra Bagged Upright Vacuum
    Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
    sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
    Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
    Bissell won't turn on
    the motor could be ceased up. do you hear a buzzing noise? if you dont hear a buzzing noise, turn it on for about 1 minute, unless it starts smelling hot or starts smoking. if nothing happens after that, try replacing the power cord.
    Feb 01, 2009 | Bissell 6594 PowerForce Bagless Upright...
    Won't turn on; no lights, no power.
    Did you try a different outlet? The cord may have gone bad, most of the times I find that people don't pull the plug out of the outlet by the plug, they just pull the cord, or it got yanked out some other way and that will break the wire inside the cord. Other then that, it would have to be taken apart to find the problem.
    Apr 24, 2008 | Electrolux Epic 6500 Vacuum
    Vacuum will not turn on
    Of course it could have nothing at all to do with the sweeper. Has anyone checked the outlet you tried to use? It may be at fault. Someone may want to check the circuit breaker box for a blown breaker leading to that particular outlet. If that is not the problem, you should be able to call for repair services as the NSS Pacer is an industrial sweeper and must have a pretty good warranty.
    Feb 09, 2008 | Vacuums
    MY HOOVER Steamvac F5906-900 does not run
    There is a switch, but could be a bad cord, or the motor went bad.
    Jan 06, 2008 | Hoover F5906-900 Upright Steam Vacuum
    Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue Logo
    549 people viewed this question
    Top Bissell Vacuums Experts
    Marvin
    Marvin
    Mike
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
