Question about Refrigerators
Squeals heard from my fridge compressor
I have a National 2 Door refrigerator. I got the old compressor replaced three years back. Until today i.e. 14th June 2010 it was working okay except with intermittent loud ''plonks & clonks'' as if a pressurized bubble is bursting in oil. Suddenly today I heard a loud squeal as if a rodent or a small puppy squeals and yelps in distress. I went nearer to the fridge and tried to determine the sound source & confirmed that it was the compressor. I also deciphered that the sound seemed to me like a motor jamming up in its flange and collar portion and trying to turn with great effort. I immediately switched it off. After some time I switched it back on and the squeals were there but much less. I repeated the switch off & on 3 to 4 times and then the squeal simply vanished. and the compressor - to my surprise - ran quieter than these three years. (I can say that it is running as I touched it to feel the running motor's vibrations).
But what baffles me most is the squeals. Please could anyone tell me as to why the squeals emitted from the compressor?
    Sergeant:
    Champion:
  • 218 Answers
what you thought of the sound is correct. the compressor might have gotten a little rusty after running 24hrs. if turning it off helps then do so but make sure you have everything important removed from inside the fridge. solving this problem can only be done by a repairguy as it has to be opened up.
Posted on Jun 15, 2010
Fridge works intermittently
Some Of These Fridge Freezers If You Open The Door For The Freezer There Is A Switch Between The Fridge And Freezer Door Mine Done The Same And I Had To Replace That Switch It Turns The Fan On When Door Is Closed And Off When Open
Nov 04, 2013 | Refrigerators
Hello, I have a Kitchenaid Superba KSRB25FHSS02 side by side refrigerator. It was made in 1999 and came with the house. Two years ago, the compressor went on it and we had it replaced. A couple days ago,...
It's really up to you, to decide whether you want your refrigerator to be fix or replaced and buy a new one. You need to calculate the cost between repair cost and the price of a new refrigerator. Which one is suited your budget plus the convenient of the trouble free unit for many years to come.
Since your refrigerator is about 12 years old already and it's undergo several repair, including the most expensive compressor replacement. I think it's economical to spend for a brand new unit.
New unit have service warranty of about one year, it will take many years before it undergo service repair if you use and treat it with proper care.
Good luck on your decision.
Jul 03, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Ge profile fridge tfh22pr. everthing is working ok, but when compressor shuts off a very loud clunk type noise is heard. happends amost evertime compressor runs. fridge is approx. 15 yrs old
Hello
The compressor, which is the heart of the sealed system, is that big black steel ball in the back of the unit. Inside is a little pump that is suspended by three or four springs. One of your springs is broken, and when the compressor shots off it bangs against the inside of that ball.
A replacement compressor is no longer available, and even if it were, the repair would cost would be too much to put into a 15 year old unit. ($600-700 min.)
There's no way to tell how long it will run. I've heard stories that ranged from days to years. This should give you time to do a little research on a new unit, and formulate a plan for immediate food transfer if it fails.
There are a lot of sources for the research, but I always suggest people call a couple of service centers that are factory authorized on several brands. You can usually catch a road tech in the shop shortly after opening time, and they will have an opinion to share. I favor the plain jane mechanical twist-the-knob thermostat vs electronics, no water/ice, thanks. But that's just me.
Also check the warranty. Most have gone to the one year and then you lose. Extended warranty?
More research there.
Hope this helps you out, and good luck.
fil
Mar 06, 2011 | GE Profile 21.6 cu. ft. Side-by-Side...
My refrigerator does not cool any more. I put it OFF for one hour now and there is no frosting. I checked all the grids and there is no ice etc in the fridge. It is a Inglis Side by Side 2 door fridge...
Check the cycle timer this is usually 90% of call outs for this issue. They are usually locate inside fridge on the top by light ( some times on the lower outside back of unit). Put a flat head screw driver in and slowly turn until you hear a click and compressor should kick in. If this works you will have to replace timer or it will freeze up in several days but will keep you cooling until then. Good luck!!
Apr 11, 2017 | Jenn-Air JCD2292KTB Side by Side...
Fridge keeps tripping the circuit breaker
Your fridge should draw no more than 5amp. Presuming your breaker is at least 15amp there's a problem. Move to a different circuit first. If the condition persists check the start relay on the compressor. I have a suspicion the circuit may have another item you are not aware of.
Mar 01, 2009 | Whirlpool GS6NBEXR Side by Side...
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper frdige section is fine but freezer not. I have emptied, kept door shut, turned dial up but no...
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper fridge section is fine but freezer not. I have emptied, kept door shut, turned dial up but no success.
Any suggestions on what the problem might be?
Wouldn't expect problems on a SMEG just 2 years old.
You could have a bad thermostat or the refrigerator could be low on Freon, make sure you clean off the exposed coils on the back of the fridge and underneath to free it from dust and dirt – use some type of a blower for underneath and the coils you can vacuum off or wipe off the coils, if not call a service tech to have a look @ the refrigerator – it might have a bad compressor
Apr 14, 2008 | Refrigerators
Top Freezer and Fridge not working
WHEN ITS NOT WORKING DO YOU HEAR A CLICKING OR BUZZING SOUND (IF SO BAD COMPRESSOR OR OVERHEATING)SEE BELOW
ALSO CHECK THE CONDENSOR FAN IN BACK IS IT RUNNING WHEN THE COMPRESSOR IS RUNNING
Feb 18, 2008 | Frigidaire FRT8IB5EW 30" 18.2 Cu. Ft. Top...
Loud buzzing noise from compressor area and freezer not cold enough
I have a 1.5 year old GE refrigerator and freezer. This unit had not given me any problems until 2 days ago when I constantly heard a loud buzzing sound coming from the freezer. I called GE and Best Buy (bought it there) and asked to troubleshoot this over the phone. They suggested sending a technician over for $100 just for the visit + labor + parts which could add up to hundreds of dollars. So, I researched the web and blogs like this. The answer to my problem was simple. Something that I placed inside the freezer was blocking the air circulation vent. So, I turned off the whole refridgerator and I removed everything from my freezer. For good measure I dislodged some ice and frost that had developed over the vent. I carefully put back everything into the freezer, but this time being careful not to block the vent. I turned on the power and voila! No more buzzing sound!!! I hope this works for you too.
Oct 31, 2007 | Refrigerators
Temperature
I had the same problem and when we looked at the back the fan was running very slowly. We replaced the fan and that wasn't it. Then we replaced the board, bought it online for 80 bucks and sure enough that was it. Whirlpool was willing to pay for half of the part if I had once of there technicians come out. I think they know the boards are going on these. Mine is a year and half old. I have read several other sites with people having problems with the board. If the side is very hot, like ours was than this may be it. We just ran a portable fan to the condenser until we got the board in..hope this helps
Oct 13, 2007 | GE PFS22SBSSS Stainless Steel French Door...
Refrigerators Logo
194 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
