LG Vu CU920 Cellular Phone Logo
Posted on Jun 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Touch screen doesn't work
What do I need to do to get the touch screen to work? Side and bottom buttons work, not able to do anything on the sreen
Anonymous
Level 3:
President:
  • Master 625 Answers
  • Posted on Jun 15, 2010
Anonymous
Master
Level 3:
President:
Answers
625
Questions
0
Helped
344594
Points
1259
You will need to replace the touch screen to get it to work. This is a common problem with the Lg VU
Check out the following link for a video on how to do that and links to buy a new touchscreen.
Repair LG VU CU920 Touch Screen
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1356
Points
Nope no fixes to this LG Vu CU920...my advice, just don't get it. I've only had it for a year and 10days, last night it wasn't functional. It shuts off at random and I can't push any buttons that are on the screen. Also, if you do get this phone, avoid water and too much sunlight...
When i turn my 3ds on you can see all the top screen but not the bottom screen
Plug it into the charger first.try calibrating the touch screen.
you can get to the calibration menu without touching the touch screen. First, turn off your system. Hold down L+R+X. While holding these buttons down, press the power button. This should take you to the touch screen calibration menu. (See Nintendo 3DS Operation Manual, Page 15)
If it doesn't work,you need to replace the bottom screen.
please note that all games dont require the bottom screen
3helpful
2answers
Iphone 3gs screen problem
If the problem is consistent in other windows besides strictly the keyboard it is possible that the capacitive touch panel is defective or has been damaged.
4helpful
Howdo I set time on a puma watch pu910222003 blockbuster circuit touch screen
Setting the time on the PU910222003 Puma ladies watch.
The process is actually less complicated than you would think.
First, a couple things you need to know and remember.
1. The watch has a safety feature which requires you to press the touch button on the right side of the watch before you can do anything as far as touching and changing anything. If it did not, every time you accidentally touched the dial something would change.
2. Touch means you are touching the dial and the (stones or outer edge)
To change the time, day, date etc, on your PU910222003 you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Now you are ready to change stuff.
Touch the dial and the little what looks like bling at the bottom of the watch. You need to be touching the watch dial and these stones at the same time to do anything we are about to do.
While touching and holding the bottom of the dial you may see the back light turn on.
That is actually how you do that.
By continuing to touch and hold the bottom of the dial, you will then see the word hold at the top and then the hour of the time flash.
To increment the time or decrement the time, touch the right side of the dial or the left side of the dial. When you have arrived at the current hour, touch the hour at the top again and the minutes will begin to flash.
Continue to set all settings in this manner until you are satisfied. Touching the top to move to the next setting and right or left of dial to go up or down.
When you are done. Touch the bottom of the dial to exit this setting mode.
Day to day use,
Touch the time at the top of the dial to scroll through the time, chrono, alarm etc. To see time if the screen saver is on, touch the left side of the dial. Touching this repeatedly will also scroll through all the phrases programmed into the watch.
While touching and holding the bottom of the dial you will see the back light turn on.
Cool feature,
This watch actually has two displayable times you can use if you travel often to a second time zone. Press the touch button on the side and touch the right side of the dial. Touching it for a second or two will display the time of the second time zone. Touching and holding for a couple more seconds will cause the T2 on the display of the left side of the watch to flash and eventually switch to the second time. I am thinking that touching the bottom of the watch while displaying the second time should allow you to set this time also.
Feb 20, 2011 • Watches
10helpful
I have Puma-Time touch screen watch (PUMA men's Blockbuster Circuit Touch Screen Black Watch but unable to set the time.
Dont have that particular watch, but see if this works.
The process may be less complicated than you would think.
To change the time, day, date etc, on your watch you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Day to day use,
Cool feature,
My touch sreen on my iphone is frozen and when i slide the bar to unlock the screen the is no response at all i cant move the bar or anything else on the sreen, what can be the problem? is it hardware or...
Press and hold both the power and home buttons until you see the Apple logo to force restart your device.
For more iPhone / iPod touch tips like jailbreaking and unlocking, CLICK HERE or contact me personally at this email:
[email protected] or add me on Skype: ebayseller.ca
3helpful
I have Puma-Time touch screen watch (PUMA Women's PU910222002 Blockbuster Circuit Touch Screen Crystal Accented Black Watch but unable to set the time.
Dont have that particular watch, but try this.
Day to day use,
Cool feature,
My Nintendo DS touch screen will not calibrate
Take out the bbattery and click the reset button
1helpful
Swap nintendo ds screens
No the top is just display while the bottom is a touch screen. Two types of screens physically impossible to switch.
2answers
DS Lite bottom touchscreen seems "stuck"
i think you should either get a new ds or tap the touch screen hard. if tapping the touch sreen harder does not work then that means it is time for a new ds.
1helpful
6answers
Screen wont work with stylus
I have many touch screens in stock and will replace for $30 each
return shipping on same day.
[email protected]
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
