Question about Kenmore 800 7982 Dryer
Kenmore 800 dryer will not start
Kenmore 800 110.79822800 dryer will not start. Set timer and will not start. Hold the start button and turn timer. It will start as I am turning but will go on and off as I am turning.could the timer gone bad.
D. Floyd Kolb
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
ghjf
Posted on Sep 29, 2010
Kenmore 110.64942300 will not turn on. Timer still clicks
Here is a list of things that can a dryer not to start: broken belt, thermal fuse, door switch, start switch, timer, improper voltage, damaged wiring, and motor.
Dec 02, 2017 | Kenmore Dryers
Kenmore Front Load Dryer Model 97078712 Will Not Start I have a Kenmore Front Load dryer Model: 970787712 that wont start. If I hold the start button and jiggle the timer it starts. Is it correct to assume...
heatman101
Jul 21, 2011 | Kenmore Dryers
Dryer turns on, but does not run
Try to turn the drum inside with no clothes in it, does it turn freely both ways?
Then as someone is holding the start button, hold the door switch button, then try to turn the drum counter-clock wise, and see if it will start turning on its own.
If it does start turning, then the motor is more than likely the problem.
If it dosen't then the timer is more than likely the problem.
Feb 05, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore 800 7982 Dryer Logo
624 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
