Question about Vacuums
How do I make vac bags out of my roll for my VS106/b
Posted by anamullens on
TotalVac
  • 52 Answers
I believe for the Rival machine you cut some of the roll, then seal one end. Put your product in the roll then seal the other end. Generic rolls can be found at http://www.totalvac.com/tiliafoodsaverrolls.html
These will work on a Rival machine.
Posted on Jun 16, 2010
We just moved in - the house is about 9 years old. I have a Eureka Mega Boss central vac - looks like model # is CV20220. 12.4 amps, 120 volts. Can't figure out what type of bags I need. Can you...
Well, for this unit you will need any of the following bags,
Eureka genuine Part# 90610
Eureka replacement (Central vac bag)
another genuine bag style called CV-1, and/or CV-2
Kenmore Central vac bags
Most of the bags there are available at your local vacuum shop, and sometimes even Sears. The Kenmore central vac bag is, can and will fit your Eureka Mega Boss. Prices range on these bags anywhere from $12-$20 for packages of 3. Generally you will replace a bag once every 3-4 months.
Good luck,
Mark
Nov 10, 2010 | Vacuums
The bag indicator shows full but the bag is empty
In my bag vac, I have found that when the light shows the bag is full when its not that there is something between where it sucks into the vac to where it empties into the bag...maybe cat hair, dog hair....etc. Try removing the bag and running it, this may allow the air to flow alittle faster and force out the jam. You may also try removing the bottom of the vac, usually just a few screws, and checking to see if you can see the jam. What is happening is this jam is slowing down the air flow and the vac thinks the bag is full....also check the filter where the air leaves the bag area...also look where the bag connects, sometimes trash can hang there.....good luck
Jan 28, 2010 | Hoover Vacuums
Kirby g4 problem
1. Take the brush roll and belt off the vacuum. Put the head back on the vac.
2. Turn it on and see if the bag inflates with good power. Does it sound normal? This will tell you if the problem is with the motor. If you have a good inflation of the bag and a bad noise in the motor, you need to take it in for service. If the motor is fine, you need a new spinning brush assembly.
The screw heads of the brush roll face towards the floor so you can adjust them while the brush is in the vacuum. When you turn them clockwise the brush comes down and gets closer to the floor for better carpet cleaning. You should also change the belt on that vac once a year. Just because the belt isn't broken doesn't mean it's o.k. Once they stretch out the power from the motor is lost and the brush won't clean anything.
Oct 05, 2009 | Vacuums
Brush roll continue to turn while the vacuume is in the upright.
Check to see the bare floor switch is fully engaged and the vac hose is in its socket as well
Sep 06, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Hoover wind tunnel vac
If the belt is getting hot, then it is slipping instead of turning the brush roll. Check thge brush roll, make sure the ends are turning freely. Is the motor running ok? If it is then either the brush roll is bad, need a new belt, or something is catching the belt, not letting it move.
Mar 22, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
How to install kirby vaccum belts
Take the noozle off of the vac. take out the brush roll and old belt, put the belt over the brush roll and re-instal in the noozle. Turn the big square knob on the front os far as you can, it will lock in that position, then put it back on the vac and lock it down, then turn the knob the other way to release the belt unto the belt pulley.
Feb 20, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Changing belts
Turn vac over, remove the 4 screws holding the bottom plate covering the brush roll. There are 2 belts, one is a V belt ( 38528034) for the brush roll, the other is a flat belt (38528035) that goes from the larger pulley and the motor shat, put it on the motor shaft then stretch it to go over the pulley.
Jan 22, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Bissell power force
turn vac over, take of the access plate covering the brush roll, may be 2 to 4 screw. Then you can get to the brush roll and belt. It uses a Bissell Style 7 belt.
Jan 09, 2008 | Bissell 3522 PowerForce Bagged Upright...
Changing bell on a hoover turbo power 6200
Most Hoovers if you turn the vac over, remove the plate covering the brush roll, then you can get to the belt and brushroll.
Dec 31, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush is not rotating.
Turn the vac over, remove the access plate, covering the brush roll, 2 to 4 screws. Brush roll part number is 2032032if you need it, belt is a Bissell Style 7. While you have the brush roll off, check in dirt inlet to see if it is clogged, also check the hose to see if it is clogged. You won't feel suction at the bag tube, it has to have a bag on it and the lid closed before it will create suction.
Dec 29, 2007 | Bissell 3522 PowerForce Bagged Upright...
Vacuums Logo
172 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
