Omron Healthcare Omron Hem-712c 712 Blood Pressure Monitor Free Ship Logo
Posted on Jun 14, 2010
How do you clear memory, and set date and time 712c
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Jun 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
11803
Points
32
To delete all the records :
  1. Press the MEMORY button
  2. And while holding the MEMORY and the START/STOP button simultaneously for more than 2 seconds all records will be deleted.
To set date/time :
  1. Press the Date/Time Setting button to adjust the date and time (the year flashes on the display)
  2. Press the MEMORY button to advance by increaments of one year and press the Date/Time Setting button,
  3. Press the MEMORY button to advance by increaments of one month and press the Date/Time Setting button,
  4. Press the MEMORY button to set the current day and press the Date/Time Setting button,
  5. Press the MEMORY button to set the current hour and press the Date/Time Setting button (the time is set using AM/PM)
  6. And finally, press the MEMORY button to set the current minute and press the Date/Time Setting button.
2answers
My wristech I want to reset it
If you want to clear the whole user profile from its stored measurement data you also need to press the M-Button to reach to the storage retrievement mode but then press and hold the M- and the SET/SNOOZE-Button at the same time for approx. 10 seconds. This time "del ALL" appears on the display.
WGNBPW-710 manual, how do you use the mememory? How do change the date.
Do you mean the Walgreens WGNBPW-710 Automatic Blood Pressure Monitor by HoMedics? If so, the manual is available from HoMedics' support page: http://www.homedics.com/instructionbooks/ . In the product list box, scroll down to the correct model. The direct link to the manual is currently http://www.homedics.com//media/documents/homedics/instructionbooks/WGNBPW-710_IB.pdf .
If this is the correct unit, to set the date and time, press the Date/Time Set button with the clock symbol on the top of the monitor. When the hour is flashing press the adjacent + button to advance the hour to the correct one, if needed. Press the Date/Time Set button to confirm the hour and prepare to set the current minutes and press the + button to advance the minutes to the correct time, again if needed. Again press the Date/Time Set button to confirm this time and the month will start to flash. Press the + button to change this to the current month. Press the Data/Time Set button and this will be confirmed. The day will begin to flash and you can adjust this with the + button. Press the Date/Time Set button to confirm the day of the month and the year will flash. You can adjust this with the + button then press the Date/Time button to confirm the current year.
To scroll through the memory, press the Memory button. Each button press will display the preceding reading from the current one. To clear a memory item, press Memory repeatedly until you reach the reading to erase. Then press both the Date/Time Set and + buttons simultaneously; hold the buttons until you see CLA in the LCD screen.
I hope this helps.
What is a 116-386 error code
Resetting to Factory Defaults / Clearing the Memory
You can selectively clear information stored in your machine's memory.
  1. Press Menu on the control panel until Maintenance appears on the top line of the display.
  2. Press the scroll buttons until you see Clear Memory on the the bottom line and pressEnter.
  3. The first available menu item, Paper Setting, displays on the bottom line.
  4. Press the scroll buttons until you see the item you want to clear.
    • Paper Setting: Restore all of the Paper Setting options to the factory default.
    • Copy Setup: Restores all of the Copy Setup options to the factory default.
    • Fax Setup: Restores all of the Fax Setup options to the factory default.
    • Fax Feature: Cancels all of the scheduled fax jobs in the machine's memory.
    • Advanced Fax: Restores all of the Advanced Fax setting options to the factory default.
    • Sound/Volume: Resets the sound and volume settings to the factory default.
    • Machine Setup: Resets all of the system settings, such as the machine ID, date and time, display language and save modes, to the factory default.
    • Set Report: Clears all records of your faxes sent.
    • RCV Report: Clears all records of your faxes received.
    • Phone Book: Clears the speed dial or group dial numbers stored in the memory.
  5. Press Enter. The selected memory is cleared and the display asks you to continue clearing the next item.
  6. Repeat steps 2 and 3 to clear another item.
  7. ORTo return to Standby Mode, press Stop/Clear.
http://www.support.xerox.com/support/enus.html
1helpful
How do you delete the memory?
To delete the memory of Omron HEM-712C follow the procedure...
  • Press the MEMORY button
  • And while holding the MEMORY and the START/STOP button simultaneously for more than 2 seconds all records will be deleted.
2helpful
How do you clear the memory on model # 271245 (38W1-A)
Push and hold MEMORY key. While holding this, push and hold the SET TIME/DATE key. You will see a message. Let go of the keys. The memory is clear.
4helpful
2answers
Hello; My Omron HEM 712C shows message: EE Can
'EE' means cuff is underinflating. Re wrap cuff with varying amounts of pressure and restart [wait 2 minutes between readings].
Finepix S9500 keeps clearing preset settings
The on board memory battery is flat. This is usually a watch battery type which is soldered to the board
4helpful
Program date and time on the microlife bp monitor
http://www.microlifeusa.com/files/manual/files/MLU3MQ1-IB.pdf
4.3. Setting the date and time
With the unit OFF, press the Time/Date button on the side of the monitor and hold for
three seconds until you see the icon start flashing in the upper left corner of the
monitor screen. The Memory button becomes your scroll button and the
Time/Date button moves you to the next time, date or user.
When the User icon is flashing, you can toggle between User 1 and
User 2 by pressing the M (Memory button). If you press the M
(Memory button) one time and the User changes to User 2, you can
press the Time/Date button to set your unit on User 2 or you can press
the M (Memory button) again to go back to User 1. Either way you
must press the Time/Date button on the side of the monitor to confirm
the setting and move on. The unit will automatically move on to the
Time/Date settings. If you don’t want to change the Time and Date
then just keep pressing the Time/Date button six times until nothing is
flashing on the monitor screen.
If you want to change the Date and Time, then press the Time/Date button once the correct
User is flashing on the screen so you can move on to set the correct year.
The unit will automatically move to the Year setting after the User has been set. To
change the year, press the M (Memory button) to scroll forward. Please note: You cannot
Time/Date button
on left side of
monitor.
scroll back so scroll slowly so you don’t miss the correct year. If you do pass the correct year
the unit will scroll all the way to 2050, then start again at the year 2000. Once you select the
correct year, press the Time/Date button to set it and move on to set the correct month.
Then the Month will begin flashing. Again, use the M (Memory button) to select the correct
month and press the Time/Date button to set it and move on to the day setting.
After you set the month, the Day will begin flashing. Again, use the M (Memory button) to
select the correct day and press the Time/Date button to set it and move on to the hour setting.
After you set the day, the Time hour will begin flashing. Again, use the M (Memory button) to
select the correct hour according to AM or PM and press the Time/Date button to set it and
move on to the minutes.
The last setting is the Time Minutes. The minutes will be flashing. Again, use the M (Memory
button) to select the correct minutes and press the Time/Date button to set it and complete
your setting.
Please NOTE: You can cancel out of setting the User/Time/Date by pressing the Start/Stop
button. If no operation occurs during the User/Time/Date setting process, the unit will automatically
cancel out of it. To re-initiate the setting process, press and hold the Time/Date button
for three seconds until the User icon begins flashing. Start the procedure all over again or
press the Time/Date button again and again until you reach the desired location to reset.
Top Omron Healthcare Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Omron Healthcare Health and Beauty Expert? Answer questions, earn points and help others
