Frigidaire Over-the-Range Microwave Logo
Posted on Jun 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Microwave not heating and it is making a humming sound when it's on
Anonymous
Level 3:
  • Frigidaire Master 43,501 Answers
  • Posted on Sep 30, 2010
Anonymous
Frigidaire Master
Level 3:
Answers
43501
Questions
0
Helped
10842952
Points
101584
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gjkk
Why is light staying on and its making annoying humming sound?
The door switches are either faulty or not being depress when the door is closed, this usually means that the door and the cabinet are out of alignment
What causes a ge spacemaker above the range microwave to quit heating and makes a deeper pitched noise?
This louder, 60 cycle hum is usually caused by a bad magnetron. The unit will not heat when this happens. Repair cost can exceed $100.
GE microwave JE1660WB001 does not heat makes humming sound
The magnetron has gone and is the heart of the microwave oven, this part is the most expensive to replace, cheaper to buy new in the long run.
1helpful
Microwave works but food not getting heated up
If the microwave is making a humming sound, then the diode is bad and needs to be replaced. If the microwave sounds almost normal but just not heating, then the magnetron is bad and needs to be replaced.
8helpful
Runs but has loud humming sound. Does not heat. Turntable, timer and lights work.
The diode that connects to the capacitor needs to be replaced. Once its replaced microwave will begin to heat again. (If it wasn't heating and wasn't making a humming noise, then your magnetron would need to be replaced). If you are thinking of doing it yourself and need instructions, i'll be glad to help.
1helpful
The microwave is making a loud humming noise when it is on and it isn't heating. It also has a burning smell. We had this microwave repaired replacing the magnetron and diode in Jan. 2006.
sounds like same problem again.... the magnetron is what does the heating and if the display is working and just humming sounds like the mag is not coming on .... could be the capacitor but most likely the magnetron again..... i am a appliance /heating and air company out of texas we work on these things everyday and is very common problem... thanks a/c and heating unlimited good luck
Runs normally, but makes loud hum. not heating. in defrost mode, loud hum, then normal sounds, then loud hum, then normal...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
My microwave kenmore 66222500 makes a humming sound like if it was on when the door is closed. i have to unplugged it or leave door open to stop the humming sound. I tested the magnetron, the primary and...
Possibly a shorted relay on the main timer board?? hum coming from transformer being powered with no fan running. With No fan you can hear it hum. shorted power relay on main board.
1helpful
It is making a humming noise but not heating.
sounds like a crack in the magnetron
a bad transformer
or a bad rectifier
sorry i cant be more help
3helpful
GE Microwave making loud humming noise
humming sound is your magneto going out Dont have any idea of the cost for replacement however it may be cheaper to purchase another microwave than to repair this one. Good Luck
Dave
Top Frigidaire Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
