Use the menu to go to the tools tab on the left-hand side of the screen. Enter the tools settings and go to the date/time setup and adjust accordingly.
Press the MENU/OK button. Press cursor-left then select the wrench icon. Press cursor-right, then use cursor-up/down to select the clock icon. See page 14 of this manual.
Most digital cameras do NOT print with the date.
However, you can ask someone at your printing location if they can help you with this problem.
Sorry I could'nt give a direct answer!
Press the MENU/OK button to bring up the menu. Press cursor-left to select a left tab. Use cursor-up/down to select SET. Press cursor-right to enter the setup menu. Use cursor-up/down to select "DATE/TIME" and press cursor-right.
The full instructions are in "The Setup Menu" section of the manual (page 83 in my copy). If you need the manual, you can download one at http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/xp/finepix_xp10_manual_01.pdf
Try this. While in Shooting Mode Select the Menu/Ok button ( center ). This brings you to the shooting menu. To the left, the "Camera" Icon is highlighted and in red. Select the button that looks like the flower ( at 9:00 position ). The "Set" Button should now be visible. Select the Timer Key ( 6:00) and Set should be highlighted. Select the Menu/Ok again and Date/Time should now be enabled. Select the Bent Arrow Key ( 3:00) and here the date format and time can be changed. Hope this helps. Therese
The full instructions are in "The Setup Menu" section of the manual (page 83 in my copy). If you need a manual, you can download one at http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/xp/finepix_xp10_manual_01.pdf
Unfortunately no, that particular camera cannot stamp time and date directly on the photos. Date and time info is embedded in the files and can be viewed on your computer with nearly all photo organizing software.
go to the setup menu and arrow over to the hour. Go up or down on the hour and the AM/PM should change as you pass the 12. If not, it's probably defective and should be repaired under warranty for you.
