Terk XMD1000 Satellite Radio Receiver Logo
Question about Terk XMD1000 Satellite Radio Receiver
Why does my xm radio always have to be refreshed after my vehicle has been turned off. The poer to the radio is not lost because the clock is always running. I have to refresh the radio everytime I want to use xm
John
  • Terk Expert
  • 509 Answers
You need to have one wire on an always 'hot' power feed. Be careful, as some GM products have a timer that shuts off the power after a 10 minute timer, so that could be your issue. Are you talking about a factory installed XM, or one like the photo above?
Posted on Jun 15, 2010
Concert class XM radio. My signal is intermittent. May not receive signal for hrs and then it just comes on for while. Been doing this for about a year. It gets progressively worse. Just changed the...
How do I refresh my XM signal?
The refresh signal will be sent from a satellite, so make sure your vehicle is outside and your antenna has a clear view of the sky. Turn your radio on and tune to Channel 184 for Sirius radios or Channel 1 for XM and SiriusXM radios. Simply tune to Channel 4 to verify your signal. http://siriusxmca.custhelp.com/app/answers/detail/a_id/252/~/resending-your-radio-signal
Why does my XM radio lose its signal when the car's power is off?e car. When i refresh the signal it comes back on, but when I turn off the car, the signal is lost. xm technical support told me
Hey sorry i do not have an answer for this but did you get this fixed. i had the alpine cde124xm since june 2011 and had xm activated for a year with no issues. however this sunday it started to happen i shut the car off it looses the signal and needs to be refreshed. Sorry to post this here but i couldn't find a way to contact your directly. Just wondering if you found a fix
2helpful
How do i refresh xm radio ?
Go to Channel 0 and get your serial number. Then, make sure you have a good signal, leave radio on Channel 1 for 1/2 hours after calling 1-800-XM-RADIO and ask they to refresh your radio. They will tell you how long to wait - okay?
Every time I get into my vehicle my XM radio will only play the Preview channel. I call and do a refresh and it will work. If I shut the vehicle off, Istart all over again. Any suggestions
Turn the radio off using the POWER button on the radio and turn it on with the POWER button on the radio as it tends to lose settings and it's brains if you turn it off an on with only the car and start the car with the radio automatically on. Use the Power button and it will solve many problems like this. Let me know how it works out for you.
2helpful
ID 4Z9AB0MC activated 2 days ago. Cannot select channels. Thumbwheel only displays 3 channels, ch.0,1,247. When pre/dir is pressed and a channel is selected, the selected channel number flashes...
Use plug-in power supply and leave on channel 1. Call XM (1-800-XM-RADIO) and ask them to "refresh" your radio. WAIT 1/2 hour, then check your channels. Make sure you have a decent signal too (can hear Channel 1 okay) before you call XM for the 'refresh signal' for your new radio.
2helpful
Xm radio installation in house
hi there..this will be like a walk in a park...first, in your home kit you should be having the ff: antenna, rca cable(audio cables), power adapter & docking station. We just have to 'placed the radio into the docking station' then we just have to plug in the ff cables into the xm receiver..we can start plugging in the rca cable(one ended connector) into the ' audio out ' of your xm radio...the other ends of the rca cables should be plug in into the 'audio in'(at the back/infront of your sound system)...plug in the antenna in the 'antenna out' of your xm( the antenna should be placed into a south facing window and not being block by tall trees and buildings outside)....plug in the power source and turn on the radio....if you got it right you should now be getting the prev.channels/emergency allerts...u can call xm to send a refresh for you to get the complete channels..or you can do it online by logging into www.refresh.xmradio.com(if the radio was already activated) if not, you have to call xm radio to activate it..enjoy listening to xm..Godbless..
2helpful
MyFi FM Modulator Stopped Working?
hi there..there are few ways on installing xm into your car..you can use the FM Modulation that you're doing before..it goes like this...make sure that you're xm radio is turn off( with all the wirings unplug).....then, you just have to go on a blank channel(e.g 90.1) on your car radio...afterwhich, turn on your xm radio and go to MENU....and look for FM settings...and select the same frequency you have into your car radio...and just have to wait for 5 to 8 secs and you should be getting the prev. channels.....
IF: you're only getting prev. channels such as 1, 130 etc...you just have to call xm to send a refresh signal OR you can go to www.refresh.xmradio.com if you want to save more time...just type in your 8 digit radio I.D....
IF:
you're not getting the FM settings.....you just have to click the MENU and select the 'default settings/factory settings' then turn off/on your radio to save the changes...
i'm sure it'll work nowq at this time....Godbless!
Delphi MyFI
I have the same problem, and only the same few channels are shown on the channel access screen and they all have + signs.
KDC-MP532U (Lost ESN # ??)
That will be a problem with the XM box you connected to it, call xm see if thay can help, the radio is just liike a screen for the XM nothing more the box controlls all of it.
Don
XM reciever FM transmitter problem
hi Mr.Frazier....is the xm radio hardwired installed? if it's a yes you have to go to a professional(bestbuy, retailers) to have the connection check.. the problem is not within the xm radio..it's on how it was installed or set up...
If the radio was not built..well, that's much better we just have to check the audio connection from you're xm to fm radio (make sure to check if what band it is connected..such as AUX,CD etc.) if there's a sound but you're only getting preview channels..refresh must be send on the radio...you can call xm to ask for that OR do it online at www.refresh.xmradio.com and type in your 8 digit radio I.D just have to follow the activation instruction faithfully...Godbless!
Top Terk Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Terk Audio Player and Recorder Expert? Answer questions, earn points and help others
