Decalcify...
(read the manual)
Personally I prefer the French press for small batches...
That way the GOUNDS can make it to the garden...
(where they belong).
VERY QUIET
Carnac the Magnificent
SOURCE: Keurig B50 Ultra brewer
This is a known problem with the B50 which Keurig will acknowledge if you press them hard. Some users have suggested trying to clean the check valve just inside the water outlet but the best solution is probably to call customer support, complain like crazy, and take the discount on a new machine that they will offer you. Apparently, this problem occurs much more often with the B50 than with more recent models, which may explain why it isn't on the market anymore.
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
SOURCE: My Keurig coffee maker is not brewing the size cup
Hello. I recommend that you descale your machine. Here is how to do it: http://www.keurig.com/help/De-scaling_instructions.pdf?mscsid=27SCSLLH993M9P2RCE7EGD5S1AK660A1
Please reate my answer as very helpful. Thank you. Joe
SOURCE: Keurig Platinum shuts off after one brew. Will
I came up with a very simple workaround to fix this issue:
http://www.nate-lewis.com/blog/?p=288
The problem is with the water tank not having a proper seal to the brewing unit.
