I could provide you with written instructions to clear paper jam, however i thought it would be good to provide you with a link to solve it for better understanding.
Click on the link below and it will give you step by step instructions to clear a paper jam with video demonstration.
Indikator paper jam di status monitor bisa berarti benar-benar paper jam atau carriage problem. Coba dibongkar dulu printernya, mungkin ada sesuatu yang nyangkut pada paper feeder, bersihkan sekalian paper sensor pada paper feeder. Kemungkinan kedua adalah problem pada carriage atau bisa jadi pada chip di ink tank. Coba dulu ganti chip pada ink tank dengan yang lain ( yang baru atau yang arc). Salam dari Arema
One problem i found with those printers is that over time the casting around the paper tray is wearing off and printers starts to show paperjams when there is no paperjam.
One way to fix is try and positions the paper tray better or perhaps raising it a bit with piece of wood or paper.
Cast unfortenately is too expensive to replace so if this doesnt work and you are sure there is no paperjam and nothing obstructing the sensor then replace the printer.
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
its a mechanical problem ... check the rollers of the printer ..and the paper pick mechanism ..maybe it can't caught the paper in the tray that why it display an error of jammed..
OKI C7300
