thank god, I found my problem's solution, it is easy to solve, just press function key + 32 to cancell alarms and then see what happens? press *32 to remove ESQ-BSY sign, if you find this helpfull don't forget to say helpfull.thank god, I found my problem's solution, it is easy to solve, just press function key + 32 to cancell alarms and then see what happens? press *32 to remove ESQ-BSY sign, if you find this helpfull don't forget to say helpfull.
You can't post conmments that contain an email address.
https://www.fixya.com > ... > Mitel
Press Function 2.Press [ALARM] 3.Press [SHOW 911] This will show what extension calls the 911. 4.Record the number of the extension from which the 911 call ...
It's in a table of allowed numbers. If you're familiar with the system, you ought to be able to find where 800 and 888 are allowed. Just add 877,866 and 855 as entries.
If ARS is implemented, you'll find your entry in the 700 table, maybe :-)
I don't envy you if that is the case.
Need a tech to come out there. Is it a comcast phone or a comcast phone line. Comcast line you need to connect it to a LS/GS trunk port. You my need some programming.
Negative, the SX 50 does not support CID. You can upgrade the Mitel or use a CID Multi line interface to a PC. Here is one such model. http://www.callerid.com/
If you go to the bottom of the page on the right, click on how it works. Hope this hlpes.
