Kodak EasyShare V570 Digital Camera Logo
Posted on Jun 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What due i due when a error #e45 is on the screen
Anonymous
Level 3:
  • Master 6,831 Answers
  • Posted on Dec 14, 2010
Anonymous
Master
Level 3:
Answers
6831
Questions
0
Helped
1214714
Points
16134
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Kodak EasyShareLS753 screen has camera Error #E45 what is problem and how do I fix...turn the camera off and then on. if you encounter the same error, go to
Hello and Welcome to FixYa!
E45 error message sometimes means that the lens is misaligned, This error is also may be due to failure of the control system.
To solve this follow the given solution:
You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service center.
You must keep in mind that to open the camera without good experience is not recommended and might tamper the delicate unit so best option is to Contact Kodak to see if your camera is still under warranty, otherwise contact any Kodak Cameras service provider, your problem will be solved.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you for using FixYa!
3helpful
How to fix error E45 on a Kodak V570? my camera stop functioning and only "Camera error E45" on the screen, all buttons and do not respond, only on/off button is working.
The bad news is that this error means the lens alignment of your camera is messed up and it will take repair service to fix it. The cost of this might be equivalent to replacing the camera.
Thank you !!
De camera geeft error #E45
This is a lens error. KODAK suggests a repair for this fault.
However due to spare part shortage this model is no longer repaired. Instead KODAK offers a trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
My camera kodak easy share v530 has error e45 the zoom doesnt go in when i turn it off. when i turn it on it says error e45
E45 means it has a lens error., the gear of the lens is already defective you need to call precision camera for repair toll free 1 800 665 6515
Nov 01, 2009 • Cameras
Error E45
It's a lens fault and the camera needs a repair.
OoW. repair of 88,07 Pounds ex shipping
Contact KODAK:
1helpful
E45 Error
turn the camera off and then on. if you encounter the same error, go to www.kodak.com/go/itg to either avail of the service upgrade program or get it repaired.
Camera error # e45
http://www.digitalcamera-hq.com/digital-cameras/kodak-easyshare-ls443_question.html?qid=5943
Try your luck
I bought one yesterday new for 25 $, so ...............
Bit more plastic then the previous Kodak but 10+ megapixel and video and moving shot ok.
Rate me for a good advice
2helpful
2answers
Screen says error#e45
mine says the same thing can anyone help? manzanero26 is my y
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
