I suggest to upgrade your hard drive to SSD. That would make you laptop fly. Just start your laptop within 30 seconds. Check the post how to upgrade the hard drive. No need to change a new laptop cost your hundreds of dollars.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
I am not familiar with connection process, but the speed of
the internet can be evaluated from, http://www.ip-details.com/
which gives us all the data we
require.
#1 Make sure your laptop is free from virus, spyware and trojan. A virus or spyware can make your laptop run slow or even damage the whole system. Run a security scan to find out if there are infection files hidden in the system. The slow laptop would be fixed by eliminating the virus.
#2 Remove obsolete programs to release more hard drive space. Laptop slow problem sometimes would be caused by the less hard drive space. To optimize your slow laptop, you can try to delete those unneeded programs, files from the hard disk especially the system disk.
#3 Empty the Recycle Bin to retrieve more system resource. Your laptop slow symptom maybe arises due to the deleted files in the Recycle Bin. If you forget to empty the Recycle Bin, those files in fact still exist on the hard drive and keep eating up your laptop system resource so that the laptop will run slow.
#4 Scan and fix Windows registry. Do you know how important registry is in Windows system? Corrupted, invalid or malicious registry will slow down your laptop and make it run unstable. You would receive many error messages such as dll errors, Internet Explorer errors or blue screen of death in the using of laptop. Thus, it is necessary for you to fix your slow laptop by cleaning registry errors.
Try deleting all unwanted files like Temp files, disk clean up, disk defragmentation.
