Question about Sony Ericsson Reusable Screen Protector for W705 / W715
I was drinking some water and my phone was on the table next to me when i put my glass of water down by accident it dropped and spilled on my screen i didn't know what to do so i just let evrything dry out everything is working but my screen has water drops on it I've tried puting it in a container of rice but that doesn't really work and i don't have garuantee on my phone so i can't replace it please tell me what to do help ps; my parents don't know and i wanna sort it out before it's too late. :)
Anonymous
    Novelist:
  • 152 Answers
Do not turn on the phone again before taking out all moisture. Take out the battery, sim card, etc. You will need to wrap in newspaper each, the phone and battery and then put in the rice container and wait at least 24 hrs. I hope this helps!
Posted on Jun 14, 2010
1helpful
Ihave had Hiccups for two days and need a method of stopping so I can get some sleep
Hey there "Lanier" do you still have the Hiccups ? if so, I will tell you how to get rid of them in 30 seconds.
get a medium size glass (10-12oz) fill it to about 1" full from the top, now while standing up, drop your head down put the glass to your mouth so that your trying to drink off of the opposite side of the glass than you normally would, so that your chin is actually in the glass and so the bottom of the glass is going back towards your chest, now as you slowly bend forward from your waist, start drinking the water out of the glass, (its like your trying to take a drink in the opposite fashion that you normally would) . Now you might spill a little but its ok, you only need to drink a small amount of water, now when your bent over and have had a few swallows of water, keep your head bent down for 10 seconds or so and now stand back up and pour the rest of the water down the sink because your Hiccups are gone.
Here is why this works, (it's actually a biological plumbing thing) the " Hiccups " are nothing more than an air bubble in your digestive system, so by bending over and drinking the water in this fashion, it lets the water run into your system and the air bubble to escape over the top. ( BTW my dad taught me this trick in 1965 and I've cured a million cases of Hiccups, plus I've won a lot of money in the bars showing people how to do this ).
You can thank me later...
tip
Cocktail Candles
1--Blocks of wax--2 Crayon--3-Cocktail glass or Mug--4-Straw or Cocktail umbrella--5-Wick or mop string- --Cut uncolored wax into ice cubes.Put to side-Melt wax and crayon (your choice of color)-Drape wick from pencil into glass-Drop in straw-Fill glass with colored wax- Mash wax ice cubes in to drink before colored wax gets hardLooks very realSet on bar or table
on Apr 13, 2014 • Crafts & Hobbies
tip
How to get rid of hiccups
1. Get a glass of water. 2. While holding the glass and making sure not to spill the water, bend forward at your waist at an almost 90 degree or perpendicular angle. 3. With the glass in front of your mouth, drink at the opposite side of the glass. If done correctly, this would make you bend your head forward as you drink. It would seem like you're drinking in an upside down manner. 4. After 3 or 4 gulps of water, stand up straight and it's a surefire that your hiccups are gone!
on Apr 26, 2011 • Health & Beauty
Past tense
no-- all present tense
it is all things to do now
Past tense
this is a site for fixes not complaints
tip
I take an old pair of hose (womens), buy some loose tobacco, cut the hose to...
I take an old pair of hose (womens), buy some loose tobacco, cut the hose to about 1 foot, 30cm long making sure there are no holes in the toe or elsewhere, put a 1/4 cup or so of tobacco into the sock, tie a knot so the tobacco stays put. Then open the bonnet of the car, find the windshield wiper water tank, drop the end of the sock into the solution or plain water, make sure the upper end of the sock is securely fastened to something outside the tank so you won't loose the bag you created and you'll be amazed at how clean the windscreen will be next time you use the wipers after squirting the windshield as usual.
An alternative would be to boil the sock in water like tea, but don't drink it! after 10 minutes of boiling, let it cool, squeeze the bag so all the "tobacco tea" goes into the pot. When cooled, pour it into your windscreen water tank. As you wash your windscreen with the wipers going the squirted liquid will clean the glass and make rain water sheet off rather than leave droplets. You can actually drive the car safely because you can see as if no rain was falling.
If your wipers stop working all together and you can't see to drive, take a sock, as the one I described above, get it wet and wipe the windscreen with it. The rain will then sheet off the glass as if there was no rain at all. no drops can form. The tobacco breaks the surface tension. Want proof? Take a glass of water, fill it to the top just short of spilling over. You'll notice the water actually rises above the edge drop one grain of tobacco or black pepper and the glass will immediately spill the water out of the top of the glass. I keep such a bag in a plastic bag under my seat. You never know when you might need it. You can use it many times before needing change the tobacco.
If you just want some cheap glass cleaner, mix a 50% solution of white vinegar and pour it in your window wiper water tank. It will keep your windscreen nice and clean; also streak free.
We dropped it in a glass of water. everything else works but the sound
Hi, a phone with no sound means the ringer is bad,due to the glass of water that spilled on the phone.
You will need to replace ringer inside the phone.
Take care.
Aug 12, 2010 • Cell Phones
Flap on ice dispensor does not close.
The flap is probably gummed up with sugar from filling glasses with sugary drinks in them. When the ice drops into the glass it splashes the drink into the chute. It needs cleaning.
Just flushing plain water over, under, around and through it will probably free it up (yeah, I kow it's going to be messy).
Water spill
should still have warranty but not all warranties cover this.
do not try and take it apart to dry yourself or all warranty for the laptop will be void.
i recommend you return it and let them fix it
even you have to pay due to the fact that even if it does dry out and become workable again you will have corrosion.
i also recommend no food or drink by the laptop to prevent accidents.
Let me know if this helped
please rate me
thanx
Spilt Beer/Soft Drink on Camera
Screwed. you can try sending it into repairs but they were probably charge you more to fix the camera than what it's worth.
Sony Ericsson Reusable Screen Protector for  W705 / W715 Logo
Top Sony Ericsson Cell Phones Experts
Ekse
Resolution IT Dubai
Resolution IT Dubai
Oloyede Monsuru
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
