Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Jun 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My whirlpool duet washer is leaking water from the detergent compartment. Looks like the water can't get through the hole under the detergent compartment before it gets to where clothes are How can I open to get access and see what could be blocking the water?
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Sep 30, 2010
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5034677
Points
35540
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Water leaking from under my 2010 Whirlpool duet washer
First places that I would check are hose connections and the seals on the water pump...
If the seals are leaking the pump has to be replaced.
The fabric softner compartment of my whirlpool duet washer is completely full of water
Mine is doing the same. For over 2 months now I've been adding fabric softner to the detergent compartment but I broke down and called a repairman to come tomorrow... at a ridiculous repair rate. My washer is less than 3 years old and this will be the 3rd major problem that needed to be fixed. I've seen a lot of people post the same problem - some say all 3 compartments won't drain.
My Whirlpool Duet washer is leaking from the
2helpful
2helpful
Whirlpool Duet Sport WFW8300SW02. Water pours out detergent disp
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%%%%
1helpful
Detergent dispenser door left open would it cause a leak in front
spash over...its made to channel water down open or close...if your getting water down the front i would check,,the bellows,,or gasket..that big rubber tube between the front panel and the tub,,for a leak ,hole tear...over suddsing will alse make a leak ..make sure your using he/low suddsing detergent
2helpful
My whirlpool duet sport is leaking out of large amounts of water out of the detergent compartment. it seems as if the water will not travel into the machine. any ideas?
Which compartment is for the laundary soap
According to my information the dispenser drawer has four separate compartments for adding laundry products to the wash load. These compartments are:
1. Prewash Detergent Compartment
2. Main Wash Detergent Compartment
3. Bleach Compartment
4. Fabric Softener Compartment
Laundry products are diluted and dispensed automatically
at the proper time during the wash cycle. The separator in the Prewash and Main Wash Detergent Compartment can be moved to accommodate either liquid or powdered detergents.
Water leaking
There is a small plastic "gate" that is left down for liquid detergent and moved back and up for powder detergent. If this piece is left down and powder detergent is used, the water leaks and the detergent won't go into the washer properly.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
