How to remove Canon A570is broken battery door
I had the same problem and found nothing online to fix it so based on what little I could find and some common sense I got it done fairly easily. Here's what I did...if you need more detail on any step either re-read it to see if you missed something or let me know 'cause maybe I missed something.
Standard warning - you are dealing with small screws, small parts and things that might break. If you damage your camera trying this repair - please don't blame me! <G>
1) remove batteries and memory card
2) carefully remove screws around the outside.
There are: 3 on the bottom, 1 under the plastic usb cover on the left side, 3 on the right side. Once those are out, remove the clip that holds the wrist strap and you'll find 1 more on the top of the camera under the wrist strap clip.
3) starting at the bottom of the camera, gently separate the back cover from the camera body. YOU DON'T NEED TO TOTALLY REMOVE THE COVER!
4) (note the small spring on the battery hatch - when you complete the next step that spring will come out so look at where it is, which way it is and don't lose it!) While holding the cover and camera body apart slightly, use a pair of fine needlenose pliers or possibly tweezers & slide the pin that holds the hatch in place toward the back of the camera until the spring and door come off. You don't need to totally remove the pin.
5) take your new door assembly and put it in place. the fun part is the little spring - the shorter end of it has to go through a small hole at the back of the hinge area, the longer end puts pressure against the hatch. Once the spring is in place, hold it there and slide the pin back into place (I found that just allowing the cover and body to come back together moved it into place).
6) try the hatch to make sure it opens/closes freely and latches
7) put the screws back in place - note that one of them is shorter than all the others - that one goes on the top of the camera under the wrist strap clip
Hope this helps!
Please note - this is the only digital I've taken apart so I'm not likely to be able to help with other makes and models but feel free to ask!
Use professional camera repair tool to remove the broken Canon battery door. If you need to repair it ,why not take it to a expert repairer.
SOURCE: Canon A75 Battery door
Never did it on an S1, but on other models it required removing the back face of the camera to access the battery doory hinge pin.
Examine your camera, and if this sounds feasible, remove all screws along the perimeter of the camera (keeping track of their sizes and where they came from, write it down with a crude drawing of their locations/sizes). Also look for screws in the battery compartment, and any visible screws behind flaps/doors. Once all perimeter screws are removed, you should be able to remove the back face of the camera by prying it open from the bottom. Once opened, the pin holding the battery door should be able to be slid out, enabling removal of the old door. Then in reverse slide the pin into the new door, and reassemble the camera and its screws.
SOURCE: Canon A570IS lens frozen half way-no power
I have a a570 IS that the lense locked out on. fixing it was going to be the same price as buying new, so I took mine apart and after two tries, i fixed it. I would be willing to take a look at it for a heck of a lot cheaper than Canon can if your willing.
SOURCE: canon camera a570is kills new batteries in a day
Hi
Firstly digital cameras are notoriously hard on batteries especially if you are using normal alkalines. NI-MH rechargeables are a much better option and usually provide around 300 shots before they require recharging as opposed to alkalines which can be as low as 40 to 60 shots.
The A570 is also known to have an overly sensitive low battery warning and gives this warning off well in advance of the battery fully loosing its charge. However it does also have a tendency to "eat" AA batteries.
Recommendation - if you are not already on rechargeable NI-MH batteries move over to using them and you will not regret it. Despite the initial outlay on buying the charger and rechargeable batteries themselves you will definitely end up saving in the long run.
Hope this helps. Thanks for using FixYa.
