Tip & How-To about Nokia 6500 Slide Cellular Phone
Using the camera:
Your phone has a flash to help you to take pictures in different
lighting environments. The flash is on by default, but you can turn it
off or use the automatic setting. To set the desired mode when using the
camera, select Options > Flash and Flash off, Flash
on or Automatic.
Fast viewing with memory card
To view your images and video clips quicker, use your memory card
as the main memory for storing them.
In the camera application, select Options > Settings
> Image / video storage > Memory card.
Capture and send
You can send the picture immediately after you have taken it when
you are previewing it. To display a picture immediately after you take
it, select Options > Settings > Image preview
time and the preview time. During the preview time, select Back
to take another picture, or Send to send the picture as a
multimedia message.
Print your images
Your phone supports Nokia XpressPrint to print images that
are in .jpg format. To print your pictures, connect your phone to a
compatible printer using a data cable or send the image by Bluetooth to a
printer supporting Bluetooth technology. Select the image you want to
print from the Gallery, and when viewing the picture, select Options
> Print.
