SOURCE: Color problems with Hitachi Ultravision
Blue color has shifted. two months ago it had shifted slightly. Now it has shifted more. All three bulbs are working. Please suggest a solution.
SOURCE: 61 Hitachi Ultra Vision has double image
you will need to replace both convergence ICs they are STK392-110 you will also need six resistors (2) 2.2 ohm 1watt
(2) 1.5 ohm 1watt, (1) 3.3 ohm 1watt and (1) 1.8 ohm 1watt.
You can get replacemnet ICs and resistors at te following link with free instalation instructions. Here is the link.
http://servicemanuals.vstore.ca/
SOURCE: Many thin black horizontal lines on my Hitachi Ultravision 50" TV
Good Day, LDS also;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
SOURCE: hitachi ultravision digital 65
my tv is green the colors say that there 100 percent but the yellow is at 0 does that mean i need a new lamp, bulb or what?
SOURCE: hitachi ultravision 52 inch rear
i have a red and green line drooping down the screen and everything is out of focus
