Question about DISH Network 721 DVR Remote Control
No communication between receiver and remote
The SAT button lights up when buttons such as "guide" and "recall" are pushed but nothing else happens. The tv functions such as volume and power work fine so the remote works fine. There is nothing blocking the receiver. The remote was fine until a few minutes ago.
Posted by amandaharwoo on
Ray Calo
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 358 Answers
Amandaharwoo,
The first thing I would do, if you haven't already, is replace the batteries in the remote. The lights will still illuminate if the batteries are low but won't perform the remote functions. If that doesn't fix the problem, the remote may need to be readdressed to the receiver. I have provided the steps below. If you have further problems, please respond to the site.
  • Remote: All Other Remotes
    1. Go to System Info screen
    2. Hold down the SAT button until all mode lights light up.
    3. Enter a number between 1 and 15 using the numeric keypad on the remote.
    4. Press the pound (#) button
    5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Ray Calo
DSIH Network
Posted on Jan 18, 2011
On my dish remote for tv 2 sat button stopped working and wont light up. all other buttons work. i have changed batteries but nothing changed. How do i fix this because i dont wan to waste money on an
Kevin rico,
I can definitely check this out with you. Does the SAT button light up when you press any buttons at all? If you press SAT, can you operate the receiver?
If neither of those work then the remote most likely needs to be replaced. If you would like to try that option, just send me an email at [email protected] and i'll assist you further!
Tommy Faust
DISH Social Media Representative
Jul 05, 2012 | DISH Network 142923 Remote Control
Program dishnetwork remote
Anthony Stewart,
I hope this has been resolved for you by now, but if not I would be happy to help! Below I have listed the steps to program the remote to both the TV and Receiver. If you have any other questions, let me know!
Addressing Remote to Receiver:
1.) Go to System Info screen.
2.) Hold down the SAT button until all mode lights light up.
3.) Enter a number between 1 and 15 using the numeric keypad on the remote.
4.) Press the pound (#) button.
5.) Once the SAT button blinks three times, press record.
6.) Test remote and see if it works.
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code.
Jul 02, 2012 | DISH Network 32 Ir 137180 Remote 5900 3100...
My 5.3ir remote quit working for sattellite and tv functions,how would i go about re-programming it
Michael Jewer,
I can definitely help in programming your remote Michael. I have put below the steps to program a remote to your receiver and TV. This link will provide you with the codes for any equipment you wish to program.
Codes link: http://www.dishnetwork.com/SupportSection/apps/remotecodes.aspx
6.) Test remote and see if works.
4.) Try functions (Volume, Power, etc..) and see if working.
If you require any further assistance let me know here!
Tommy Faust
DISH Network
Oct 31, 2011 | DISH Network IR Remote Control
My remote wont work but sat and all other buttons light up but they do not work for guild or anything else plz help
Hey john_aust127. I would need more information to provide you a specific resolution, but I can at least give you some information to get you on the right path.
You can follow this link: http://www.dishnetwork.com/SupportSection/remote-setup which contains more information on programming your remote to your receiver, along with codes to program your remote to the TV. I have also provided the steps for both below.
If you have any other questions or would like any more help with this you can reach me here or at [email protected]
Tommy Faust
DISH Network
Jun 23, 2011 | DISH Network IR Remote Control
Need code to use for the tivo remote
Push the TiVo button on the remote. Then push "Messages and Settings," followed by "Settings," and finally press "Remote Control." This will show you the three areas of the remote that are programmable. "TV Power, Volume and Mute," is one section. "AV Volume and Mute," is the second section. The final section is "TV Input."
Pick "TV Power, Volume, and Mute" by pushing right on the direction pad of the remote. This will open up a list of all the brand names of TV that exist. You will find most TV brands will be there.
Find your brand of television and select that option. If your brand is not there, simply go to the TiVo webpage and under "Setup and Support" you will find others who have experience this issue. There you will find a code for your TV. This happens sometimes when the TV is a lesser known brand.
Hold down the button you are programming (i.e. TV Power) for 5 seconds until the red light on top stays on. Then enter one of the codes on the screen.
Push the newly programmable button to test its functionality. If it does not work, repeat the steps with all the possible codes available. One of the codes will work.
Push "Live TV" at this point to watch television.
Use the manual which came with your TiVo in addition to this guide. In the front of the booklet will be a starter guide, which will lead you through the steps necessary to set up your remote for optimum use.
Mar 23, 2011 | Televison & Video
I can't contol the volume on my t.v. with the dish remote. I am also unable to turn the t.v. off with the dish remote. Everytime I press the volume buttons, the mute button or the t.v. button to turn the...
Usually a remte can use the VCR or DVD set up to drive something else. Try switching the remote to VCR and emulate the codes as what the dish codes arw/ Pretty sure but just try promming one remote for every thpmg. My monet=y would be on the sat remote/
ash
Sep 26, 2010 | DISH Network IR Remote Control
Dish network code for a viore, volume/power not working
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Apr 05, 2010 | Toymax Viore 42 in. Plasma TV
Bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Oct 20, 2009 | Samsung Televison & Video
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
Toshiba TV 35A44 Volume Issue
I had the same problem, you'll probably find that that particular button will push further into the set then the others, this is due to the a weakening of a cheesy metal guide which directs the projection off the back of the button into the corresponding microswitch. This metal guide will bend and will push against the switch.My solution, (and it ain't pretty) was to unplug the set, remove the button( I used a dremel cutting bit), locate the guide,a small metal plate with a hole in it. Bend the plate toward the front of the set then tape over the hole. I haven't had the problem since.You WILL have to use your remote for further functionality of the volume, However all of the buttons seem to be inherantly poorly designed and will weaken over time, AVOID USING THEM!
Aug 23, 2007 | Toshiba 35A44 35" TV
DISH Network 721 DVR Remote Control Logo
258 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
