Clarion DB155 CD Player Logo
Posted on Jun 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to install the clarion db155 into my Mazda protege, I need help with the wiring diagram. Do I just splice the wires to match up or will I need to get a wiring harness?
Anonymous
Level 3:
President:
  • Master 3,085 Answers
  • Posted on Jun 13, 2010
Anonymous
Master
Level 3:
President:
Answers
3085
Questions
Helped
1007035
Points
9738
1helpful
Location of horn relay
I found this info for horn relay.
If more than one relay, hopefully you can see wiring colors at relay, then look at horn relay wiring diagram and match the wire colors to the
relay.
I'd check applicable fuses first. Any electrical circuit needs voltage and ground.
I need the wireing diagram to find out what wires go with what wires in the vehicle.
As long as you haven't cut the wires in the dash of the vehicle, all you need to do is purchase the appropriate wiring harness for the model of car you are installing into. That harness will match perfectly to the Clarion's harness (i.e; red to red, purple to purple, etc..). If you HAVE cut the vehicles wiring, it's a LOT more work. What kind of vehicle are you installing into?
1helpful
2answers
Need timing marks on dual cams for 2001 mazda protege dx 1.6L
Click on the following direct Link. It has the Tining Belt Diagrams that will match your specific engine. Included are instructions and directions.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2001/make/mazda/model/protege/2001_mazda_protege_timing_belt_diagram_marks.htm
Pioneer DEH-P3300 and 94 Mazda
Hello ryan_jaime,
It's good that you have an aftermarket Mazda wiring harness. It will allow you to make all of the connections in a well-lighted and comfortable location rather than fumbling around behind the dash.
If you are somewhat skilled at soldering, the most secure, electrically conductive, and positively insulated splices are made with solder and heat-shrink tubing. You can get the needed equipment from any Radio Shack, Lowe's or even WalMart. Be sure to put the heat-shrink tubing on the wires BEFORE you solder them together. I had to say that! Because I've forgotten many times! But if the soldering route is not for you, get properly sized insulated inline crimp splices and the appropriate crimping tool. Match up each wire by function on the Pioneer harness with the corresponding wire on your aftermarket harness. Most of the time, the wires will be color-for-color matched. But make sure, sometimes wires for things like "illumination", "dimmer", "mute", etc may not be the same colors.
Disconnect the negative battery terminal while you are working behind the dash. After you have the harnesses spliced together, plug the radio end into your Pioneer, remove the old radio from the dash opening, unplug the antenna and wiring harness plug and plug the other end of your spliced harnesses into the vehicle plug and the antenna plug into your Pioneer's antenna connector. Slide the Pioneer loosely into the opening, but don't secure it yet. Reconnect the negative battery cable and test the receiver. If everything works, slide it into the dash opening and secure it. Use the rear support stud and rubber bumper if needed. Install the trim ring or separately purchased dash kit as required. Put the "face-fixing" screws in to prevent removal of the faceplate if desired. Reinstall any dash trim removed and you're finished.
Hope this helps.
Wire diagram for the mazda protege stereo what
Sometimes if its the factory harness, you can see fine print on the wires telling what each wire is for. If not, remember, red is hot,black is ground, and your smaller wires all colored purple,brown, gray, green, orange, blue..there will be two of each color, one with a black stripe, that is your ground for the speaker hook up..There also might be a yellow or light blue wire, test that wire for power when the key is off, that is your memory power supply.good luck.
1helpful
Wiring from a kenwood kdc mp332 to a clarion rdb245d
and the standard radio diagram is
yellow 12v battery
red 12v accessory
black earth
blue/white amp rem
blue power antenna
orange/white illumination
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
that should help u
12helpful
4answers
Clarion radio wiring diagram
please help what wire goes where?? need a wiring diagram or manuel to install. clarion xmd1 marine am fm cd player
Top Clarion Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
