Dear
Paireyes,
Things that can stop electric dryer from heating are as listed: house fuse or breaker, heating element, burnt wire, thermostat, thermal fuse (not all models),
motor heat switch, timer, selector switch, burnt power cord/plug
To check various points here are the simple tips:
- To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.
- To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
- To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
- To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
Here is the link for the dryer and how to disassemble the dryer along with the images:
http://www.applianceaid.com/may-apart.html#common
Let me know if that helps. All the best :)
Regards,
Srinivas
