Sony HOME THEATER SYSTEM System Logo
A
Anonymous Posted on Jun 13, 2010
Surround sound only plays via cd/dvd will not play through normal tv audio. can u help me fix this
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Jun 14, 2010
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2767979
Points
24828
Only a digital source can provide true surround. If you're running the audio FROM the TV TO the receiver it is probably analog stereo only.
Why not get your TV-rekated audio from the same source you're watching - like the cable/sat box?
My Samsung TV picture is supplied via a HDMI lead
yes you need to connect audio out from the tv to audio in on the dvd surround. you need the red/white phono to phono leads, simply connect together and select audio (av,au) on the input selection.
When I play a DVD in the system I can only get the surround sound out of the speakers but no voices. If I play a CD or hook it up to my tv everything is ok.I have tried a number of DVD's and all have the...
sounds like you need to surround modes. There is usually a Stereo, Dolby, DTS, "virtual surround", 4-speaker mode etc..
When you play a CD or connect to TV it likely defaults to playing stereo or virtual surround.
With real surround, almost all of the voices are coming from the center-channel speaker (normally placed closest to the TV).
Also, check to make sure the center channel is connected properly.
Installing a pioneer home theatre dvd/speaker system.
On page 36 of the Pioneer users manual, it describes how to set your audio for HDMI interconnect. Follow the directions, and hopefully it will work. You can down load the manual from the Pioneer web site. Google "speaker system HTZ171 DVD". Click on the Pioneer site for your system and look for the download on the right side of page.
I hope this was helpful...
2answers
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
2answers
Dvd's are playing black & white via sound surround system
Check first your dvd player settings if it is in PAL or NTSC.
I need a diagram of how to hook up my jvc 5.1 surround sound to my tv, dvd and cable box
I my self don't have that exact unit, but most are similar, and i have looked up the specifications which are:
Inputs:
1 x S-video input
1 x Composite Video Inputs
1 x Digital Audio (TOSLINK) Input
1 x Stereo Audio Input
Outputs:
document.write(neg_specification_newline('1 x S-Video Output
1 x HDMI Output')1 x S-Video Output
1 x HDMI Output
INPUTS (coming from devices to the system):
1) The unit already comes with a DVD player, correct? If so you don't need to connect it. If you do, connect your DVD play via an s-video input, since a normal DVD player doesn't need a higher quality/resolution input.
2) Connect your cable box to the home theater system via a composite cable (the one with Red green blue), if it has composite outputs ofcourse. If not, do it visa versa with the DVD, if your dvd has composite. So make the dvd via composite and cable box via s-video.
3) Audio from the dvd, this would be via Digital Audio (TOSLINK) Input or stereo audio input. the digial audio will give you true 5.1 surround sound, and the stereo will only give you left and right channels, like you would hear from anything else (like a normal cd, radio, etc).
4) audio from cable box, would be again depending what you want. If you cable provider gives you alot of programming that has 5.1 surround sound (mostly HD channels), you would be better off with the digital audio. But if you watch more via your DVD, then connect the cable box via the stereo input. Again, this is to your preference, and which one you want true 5.1 surround sound from. The system should be able to 'emulate' 5.1 surround sound via the stereo cable too, but if your watching a movie, it can't really tell if a sound is supposed to come from the left rear or the left front.
Output:
5)connect to tv via HDMI if available, or S-video.
HDMI is much higher resolution (HD quality) S-video is normal cable programing or 'dvd quality'.
And the Tv would be left on mute or volume=0 since no audio is connected to the tv! All the audio should now come from your system.
Sorry if this was too vauge, but I don't have the same system and dont know exactly what/where all the connections are. If you have any other questions let me know.
2helpful
2answers
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
2answers
Delayed Sound from Center Speaker
Go to this website, make an account, go to support, help center. Thenfollow the instructions and you might get your answer.
Hope this helps. :)
Lg LH-D6230. How to hook up? PLEASE HELP! NO INSTRUCTION MANUAL!!
je kan met 2 tulp aansluitingen via de dvd speler audio out naar je tv gaan en dan de instelling aux van de dvd speler gebruiken zo kan je surround tv kijken
Can't play AUX inputs through Panasonic surround sound
Check the TV audio output setting. There may be 3 settings for audio output. Fixed/variable/none. Try all of the settings, and see if you get your audio back. If not, try a different cable between the TV and DVD player. I suspect this is a red/white RCA audio cable.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
