Question about RCA Universal Remote Control
Need code for mitsubishi tv - RCA Universal Remote Control
Posted by janice_strau on
Anonymous
    Novelist:
  • 109 Answers
THE codes for programming RCA Universal Remote Control to a Mitsubishi TV are 006, 011, 014, 019, 022, 027, 041, 056, 061 and 068.
But then if it will not work on these codes you can try these steps for you to be able to program your remote control without the code.
  1. Manually turn ON your TV
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the TV button you want to set up.The TV button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the TV turns off, press and release ENTER.
  7. With the TV on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Posted on Jun 13, 2010
Need codes for mitsubishi tv
I do not understand if Mitsubishi remote why it needs to be programmed for a Mitsubishi set but Google the model of the remote for a owner manual and a possible list of codes for whatever you are trying to program it for.
I exact replacement for a Mitsubishi TV you should only have to put batteries in it and select TV button on the remote.
Dec 18, 2012 | Mitsubishi Remote Control CK32308...
Forgot personal code i need to reset inorder for tv to work
Call Mitsubishi customer service first---to research this I would need the correct model number
Nov 04, 2012 | Mitsubishi Televison & Video
These are the setup codes for Mitsubishi TV: 0005 0151 0051 0004 0009 0254 0022 0141 0180
Oct 12, 2012 | Mitsubishi CS-27405 TV
I NEED A CODE FOR MY MITSUBISHI TV I HAVE A PH601S REMOTE
You can use these codes for your mitsubishi tv:
  • MITSUBISHI Codes: 004/ 005/ 009/ 022/ 046/ 081/ 089/ 132/ 133/ 180
  • Jun 11, 2011 | Philips Televison & Video
    I need codes for a mitsubishi tv on a RCA dtv800b1 digital box
    here you go.....
    Mitsubishi 0 0 9 3 ,0 1 5 0 ,0 1 7 8 ,0 0 1 9
    Please rate our help++++Thanks for using FIXYA
    Oct 11, 2009 | RCA Universal Remote Control
    I Need the codes for my Mitsubishi tv
    Try these .. They are from this site if you would like to look at more
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 0005 0151 0051 0004 0009 0254 0022 0141 0180
    http://www.jascoproducts.com/support/universal-remote-codes.asp
    Feb 01, 2009 | Zenith ZN-501S Remote Control
    I lost my list of codes for my tv ,I hve a Mitsubishi tv
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try these
    I need a tv code for a mitsubishi tv model-wd 62526 2006
    use your remote and press QV and 9 together. the reset the code
    Dec 19, 2008 | Mitsubishi WD-62525 62" Rear Projection...
    Televison & Video Logo
    186 people viewed this question
    Top RCA Televison & Video Experts
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
