Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Color needs reseting in the box it keep showing green red & blue needs to reconfigurating
Posted by marybarabin on
ABRsvcs
  • 4,234 Answers
If the picture looks like a 3-D one, the problem is with the convergence circuit. Please confirm the model number to be D52W20. I will supply additional details based upon the model.
Thanks,
Dan
Posted on Jun 13, 2010
My moniter is showing no signal with 3 colored stripes g on green r on red b on blue. I have a wireless logitech mouse and keyboard and the reciever is not showing the 2 green lights meaning its on. Do I...
ok your monitor is a separate issue and start by checking the blue signal lead from the back of the monitor because for some reason the monitor isn't getting any images to show
Feb 02, 2012 | Gateway Computers & Internet
What are the color codes for a factory stereo system in a 2006 Nissan alttima
use at your own risk. I can not confirm these.
+12V DC Battery(Constant) Yellow/green 31 15 Amp Fuse box on left front of engine compartment, near battery. Switched Accessory Purple 6 10 Amp Fuse block behind left side of dash Power Antenna NCA Green for antenna signal Illumination Red/yellow & red/blue Steering Wheel Control Wire Red/white, green, and blue If equipped, as for Mid-Line. Left Front + Blue/white Left Front - Blue/red Right Front + White/black Right Front - Blue/black Left Rear + Green/yellow Left Rear - Black/yellow Right Rear + Blue Right Rear - Red
titleicon.gif AT SPEAKERS
Wire Function Color Note Left Front Tweeter + Blue/white Left Front Tweeter - Blue/red Right Front Tweeter + White/black Right Front Tweeter - Blue/black
Feb 20, 2011 | 2006 Nissan Altima
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
No red when hooking up component cable for dlp hd tv. Only blue and green colors show on hd component input for charter hd cable box. Are there any internal adjustments that need to be made through either...
Check the red cable this is where the red comes from, you may have a bad cable, maybe use the blue or green one just to see if the red will come through, it can be the cable box or the tv or the cable itself.
Nov 03, 2009 | JVC HD-61Z456 Television
The color is not correct. No red. A lot of blue
if you have an lcd projector, the red lcd panel is not working or one of the filters are fried. if you have a dlp projector, the colorwheel needs replacing or the main board has an issue.
Aug 28, 2009 | Sharp Office Equipment & Supplies
Green tinted people
The only time I have had issues like this was because of the Component Cables not being in the right position (the Red and Blue connections switched), or a bad Component Cable where the Blue Connection is not receiving a signal. Swap out the cable to be sure and double check that it is properly installed. Green to Green, Red to Red , Blue to Blue.
Hope this helps,
skyassoc
Jul 18, 2009 | Samsung HLN5065W 50" Rear Projection...
I need no color code for 2006 ford taurus
+12V DC Battery(Constant) Red/yellow - Control unit in left side of luggage compartment 17 20 amp Junction box in front center of engine compt.
Switched Accessory Red/orange - In-line with the starter relay 27 5 amp Junction box in front center of engine compt.
Ground Black/lt.green
Remote Turn On(output) Brown/orange Pin 8 of CD changer. Also light green/black between rear control unit (C388B-2) and front panel (pin 4).
Illumination See notes *
Left Front + Orange/lt.green
Left Front - Lt.blue/white
Right Front + White/lt.green
Right Front - Dk.green/orange
Left Rear + Grey/lt.blue
Left Rear - Tan/yellow
Right Rear + Orange/red
Right Rear - Brown/pink
Notes
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
* Illumination is controlled from the integrated control panel, thru dark blue/white at pin 2.
INTEGRATED CONTROL PANEL has white/red for battery input (pin 11), with fuse no. 33 of 15 amps in the junction box under left side of dash; black/pink for acc. power (pin 6), with fuse 22 of 15 amps in the junction box under left side of dash; red/yellow for hot in start or run (pins 5 & 16), with fuse no. 32 of 10 amps in the same location.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 of front unit & pin C388B-7 of rear unit;
R- gray wire between pin 19 of front unit & pin C388B-20 of rear unit;
L+ brown/light green wire between pin 20 of front unit & pin C388B-6 of rear unit;
L- white/pink wire between pin 10 of front unit & pin C388B-19 of rear unit.
AUDIOPHILE SYSTEM has right and left tweeter speakers branching to right and left front speakers with the same colors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 12, 2009 | Car Audio & Video
RADIO INSTALLING
there is a code for color!? ok, wait im searching...
found it! here you go, hope it helps...
Wiring color codes are the identification colors that color the wires in your automobile. For example, if you have a British car the blue, blue and white , and blue and red wires are for the headlights. The red and white wires are for the instrument lights, and the green and white and green and red wires are for the turn lights. The color code simply identifies what that wire does. Could you imagine if all of the wires were the same color. You couldn't identify anything in a harness.
Jun 19, 2008 | 2001 Chevrolet Tahoe
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
