Question about Weiser Lock Powerbolt 1000 Lock
I have a weiser powerbolt keyless entry lock but have lost the manual. how do I reprogram it for a new combination? I've done it twice in the past but it remembers both combination and you can now open the door with either one of them! I only want it to have one, is there a way to erace the memory and reprogram it with just one?
Posted by lnahls on
1 Related Answer
sonicboomele
sonic boom electronics
  • 1557 Answers
SOURCE: How do I reprogram the
  • Remove the inner cover plate from the lock.
  • Locate the small round reset button near the left side of the circuit board (Red or Black).
  • To program, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
best of luck.
Posted on Aug 02, 2010
Lost combination
The Weiser brand and Kwikset brand Powerbolt are identical, so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Change the batteries with fresh brand-name batteries before you reprogram!
I just purchased a home with one of these types of locks on it & the previous home owner has not left me with the owners manual or the combination of the key pad, how do I program it to change the code
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
The instructions for reprogramming the code can be found there. Good luck!!
I am looking for a manuals for a weiser lock powerbolt 1000 can i down lord
powerbolt 1000
We lost the directions how do you change the code and how to get the back off
Here's a link which tells you how to remove the cover, and reprogram the lock codes:
Change combination
6helpful
How do I reprogram the entry code for weiser automatic powerbolt lock?
best of luck.
3helpful
Need to change combination
Changed battery and lost program cant find manual need reprogram 4 number code
changed the battery and lost the manual, put my code in and it worked , latter it started to beep and now it doesn't work... respond at all ....help thanks
1helpful
New combination
Here's a free manual you can print out with complete installation and programming instructions you can keep for addressing any other concerns you might have in the future.
I thought this might be easier for you to work from, since you might have to reset the lock prior to entering in your master code and other user codes, etc.
It is easy and straight forward to program and use.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful - Best regards!
5helpful
3answers
Have to change the key code? No manual.
You can change codes as often as you like, for use by babysitters, contractors, etc. You can also reset the lock so you can reset the master code, which is needed in order to set the other user codes.
Rather than re-type all the step-by-step instructions, since you also could benefit by having a copy of the manual for your use and reference, I'll give you a link to a free copy you can save and print.
Hope you find this Very Helpful and best regards!
Weiser Lock Powerbolt 1000 Lock Logo
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
