Question about RCA 36V430T 36" TV
TV worked fine until tried to turn it on just like normal with the remote. The TV power button keeps clicking, no picture. Seems like the power switch is stuck. It just keeps trying to click on and off repeated. It keeps doing this until I unplug it. Can this be repaired?
Posted by bwiest on
5 Related Answers
Simpson Neal
  • 236 Answers
SOURCE: RCA F20539DG
YOU might have a bad relay or a bad solder connection in the relay control circuit. Sounds like a bad solder joint. Stargazer
Posted on Mar 03, 2007
MikeNJ1964
Mike Longo
  • 398 Answers
SOURCE: 32" model# F32668
The F32668 uses the CTC203 series chassis and I usually see 2 problems when the set will not run. The first is poor solder joints on a small coil near the horizontal output transistor, but if thats the case the set tends to run for a while and randomly shut off. When the set clicks and never runs I usually find that the flyback (high voltage) transformer has shorted out inside. In this case the flyback should be replaced by an experienced tech.
Posted on Aug 07, 2007
Lashawn Robinson
  • 1153 Answers
SOURCE: RCA Television D52W14
The first thing in this unit is to check the ribbon cable that goes from the front control panel to the back ssb board, I would unplug and replug to make sure seated properly. Then try it again. There are alot of screws to take out but worth it if this solves the problem.
Posted on Jan 08, 2008
poacher1
Adam Phillips
  • 10 Answers
SOURCE: Continuous click noise like its trying to turn on but will not.
I have done some research and found a notorious cap and diode problem with this set. The two 4700uf caps (C14113 and C14115) on the DM1 power board (the board to the left of the sat. box when you look at the set from the back) are under rated and will eventually fail. When these caps fail they tend to take out diode CR14105. This may be your problem. If it is, you can replace the caps with 4700uf 25V 105c and the same as original diode.
Posted on May 13, 2009
Anonymous
  • 147 Answers
SOURCE: When I hit the power button the picture tube does
you are hearing the relay click.the most
common failure with this symtom is the
flyback transformer.
Posted on Jul 18, 2009
My TV still turns on and off, but there's no picture or sound. How do I fix it?
The modern TV has two power supply sections. The first is a low voltage +_5 V, very low energy consumption, to keep the remote control functions live. The main power supply seemed to have failed and could be very difficult to fix as it is a energy efficient switch mode supply. Normally the switching transistor or MOSFET fails first and the blows a fuse. Depending on the root cause, replacing these could restore its function.
Nov 18, 2015 | Televison & Video
Everything works except no picture of tv
The Television may be out of synchronization with your remote or may be configured incorrectly.
1. In front of your Television, press the Help button on your Harmony Remote.
2. Answer No when asked "Did that fix the problem?"
3. The Harmony will then ask, one by one, if all of your required devices powered on when the Activity was started. Answer Yes or No until all required devices are powered on.
4. Answer No if the remote asks if the TV is set to the correct input needed for the Activity. In this example Input 4 is used, though this may vary from your setup. If the TV switches to another input but no picture is seen, continue answering No until an image appears.
5. If you now have a picture on your TV screen, answer Yes when asked if the problem is now fixed. Your television was simply out of synchronization with your Harmony One and should now work correctly. Please try switching between your other Activities to see if they switch correctly. If this has not fixed the problem, proceed to the next section Confirming your Activity Settings.
To confirm your Activity Settings, please follow the steps below:
1. Launch the Logitech Harmony Remote software and login to your account.
2. Click on the Activities tab on your home page
3. Click on the Settings button for the Activity you wish to troubleshoot.
4. Select Review the settings for this Activity and click on the Next button.
5. Confirm the input chosen for your television is correct. Select No, I want to run the setup wizard again to change these settings and click on the Next button.
6. Click on the Next button through the Activity setup screens until you arrive at the screen asking the question "What input or channel does your ... TV need to be on? From the list, select the input that the TV uses for this Activity. Once finished, click on the Next button.
**NOTE: It is recommended to perform these steps for all Activities that use the television.
8. Click on the Done button on the Set Up Activities: Summary page.
9. Click on the Done button on the "Select the Activity settings you would like to modify" screen.
10. When you have finished, click Done to save your changes.
11. Click on the Update Remote button to update your remote.
Jan 17, 2010 | Logitech Harmony 966208 Remote Control
How reprogram my universal rca remote control
hold the tv button down and keep it down and then press and hold the power button down and hold them both until the power button stays red then let go of both buttons then keep pressing the power button until the tv turns off and as soon as it turns off press the stop button and it should work.
Aug 31, 2009 | RCA RCR815 Remote Control
Power won't come on- constant clicking loop instead
My T.V. did the same thing and it was due to bad capacitors on the power supply board. the tops of the capacitors were bulged, once replaced it worked fine. It involves sodering in new capacitors total cost $30. that includes buying the sodering tool. Keep looking around on line someone had pictures step by step how to do it.
Mar 26, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Dell plasma 42 inch
fot the most part, you have solved your problem (pow bd), The main bd may also need to be replaced as well. The is a signal upon powering up the system. the pow bd communicates with the signal board. The signal bd, also is responsible for ALL of your additional I/O lines. Between the two of these, + a firmware update, i think the tv will be just fine.
Feb 03, 2009 | Dell W4201C 42 in. Plasma HDTV
3 in one remote pictured at top of page
I googled the remote name and then when the site came up, scroll to the very bottom and click on "manuals" and the manual that lists all the codes will come up. If you do not find your specific code, try this: turn on your tv, push the "tv" button on the remote, then push the P button in the upper right until it lights twice, then push 991, then push power, and then keep pushing the channel up button until your tv goes off and that is your code.
Sep 01, 2008 | Radio Shack (15-2147) Remote Control
I have a toshiba theatre view 52-54 in.? There is no picture-it seems like the tv is off but the power button light keeps blinking. Tried using remote and button on tv. neither works.
Same problem with mine. I find that if i unplug it and let it sit for about 15 minutes ( let the capacitor drain?) i can plug it back in and it automatically comes back on and works fine till I want to turn it off again and it goes right back to the flashing power light.
I bought an on/off remote for the wall oulet and it makes a great work-around.
May 18, 2008 | Televison & Video
My tv will not turn on.
First of all, forget about the remote and see if the TV functions normally using the buttons on the front of the set itself. If the TV will not power on with the power button on the set itself, then something is wrong inside the TV. If the set works fine from the front buttons but no longer responds to that remote, then the remote has either gone bad or was accidently set to a different brand. In this case, look for the original book that came with the remote (or TV if it is the original remote) and follow the instructions for setting the remote back to Zenith. Try that and post your results here.
Aug 09, 2007 | Zenith C27A24T 27" TV
TV won't turn on.
It sounds like you have problem with the switch on the tv itself. try opening the front panel where switch is located and check wiring or maybe change the switch which you can get it online.
May 31, 2007 | Zenith IQB36B42W TV
RCA 36V430T 36" TV Logo
29 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
