Question about Haier BC112G Wine Cooler
My Haier wine cooler is working fine for the red wine section but the white wine section is at 73 degrees even though I have it set for 48. Any advice? Also, there appears to be water on the bottom of the cooler.
  • Anonymous Jun 12, 2010
    It was a gift. I don't know where it was purchased.
Anonymous
  • 26 Answers
Call were u buy it
Posted on Jun 12, 2010
I have a Haier BC112G. It is not cooling at all. Temp panel works, so I can set the thermostat up or down, but nothing happens and it just goes back to room temp after that.
Our magic chef wine cooler (mcwc50dbt) when temp is set on digital panel at 45-50 it jumps immediately back to 70 degrees constantly
Sep 25, 2013 | Haier BC112G Wine Cooler
What is the best temperature for white wine to be in?
It is important to keep the wine cool and in stable temperature that doesn't fluctuate very often. Bright tart white wine: 48-52 degrees; sparkling wine: 50-55 degrees and rich white wines: 58-62 degrees.
May 29, 2012 | Furniture
Are red wines stored on the top or bottom of the Haier BC112G wine cooler? How about white wine? Have lost my owners manual and don't know where to put red wine when the temp is set cooler for white wine
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Jun 14, 2010 | Haier BC112G Wine Cooler
What is the temperature setting for normal wine cooling?
It's between 55 and 65 degrees fahrenheit. If you're storing a lighter red wine, you'd want to keep it on the lower end (55 degrees). And for the darker (deep) red, you'd want to keep it on the higher end (65 degrees). All white wines should be on the lower end, and below. You can drop down to 50 degrees if you'd like. I hope this helps. Good Luck!
Mar 29, 2010 | Emerson (025806803716) Wine Cooler
Haier wine cooler, how to operate? No manual.
If you just want to use the factory settings then push the red or white button depending on what you store the most.
Or you can set it yourself by pushing the red and white buttons together for about 3 seconds- the temp display will start flashing-then use the red and white buttons to set the desired temp-then push the set button
Jun 11, 2009 | Haier HVF060A Wine Cooler
Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Feb 21, 2009 | Avanti WC492D Wine Cooler
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Haier wine cooler
Haier BC112G service & user manual:
To adjust the temp of your unit:
  • Push & hold the red wine & white wine button at the same time.This will start the temp adjust. You will notice the plus sign & the negative sign on these same buttons, use them to adjust temp. When you are done hit the light button & it will record the new temp.
Nov 25, 2007 | Haier BC112G Wine Cooler
Lost manual for wine fidge
Push the red and white buttons at the same time for about 3 seconds-the temp will start to flash-then press the white button to lower the set temp-when you have it where you want it then push the set buttom
Oct 18, 2007 | Haier HVF060A Wine Cooler
Haier BC112G Wine Cooler Logo
659 people viewed this question
Top Haier Furniture Experts
Colin Stickland
Colin Stickland
Dennis Boxerman
john h
Are you a Haier Furniture Expert? Answer questions, earn points and help others
