Question about Danby Silhouette DWC512BL Wine Cooler
DANBY 512BL not cooling
Hi
My Danby 512BL was running fine for 4 years. Suddenly the compressor started making loud sounds. Upon checking the rear I found that water cup had nearly overflown. I emptied and restarted. It started working again with compressor and fan both kicking. However the temperature keeps going up to 80s F. Please help.
Posted by amtsingh on
Anonymous
  • 26 Answers
Its because the weather
Posted on Jun 12, 2010
Hi I have Danby Dehumidifier about 2 year prolem is Compressor and fan running but no water and heater
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Nov 27, 2010 | Danby DDR586R Dehumidifier
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
Whirlpool dehumidifier makes a lot of noise when running and vibrating, dehumidifier is only 4 years old it does take out the water but very noisey any way to quiet it down?
When the compressors start to go bad they often start to get very loud also...the cost to replace the compressor will probably be more then a new unit...
Also check out this tip about dehumidifier problems...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
May 02, 2010 | Whirlpool AD50USS Dehumidifier
Our dehumidifier has started making more noise than it used to, it gets very hot, and doesn't collect any water. It's only 4 1/2 years old. It's a Gold Star DH 5010. We've tried cleaning the filter. That...
Yes they should last longer than that, but the sad thing is that they don't make anything like they used too...just check out all the problems in this site for a few minutes...most of the problems should never happen...
heatman101
heatman101
May 01, 2010 | Dehumidifiers
Fan runs, but compressor does not start
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Jul 05, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Bunn coffee maker reservoir makes a gurgling noise
THis sound is usually caused by the water being low in the tank. This can be because the machine is left on for long periods without being used. If this is not the case, then it would probably be your heating element getting small holes in it.
Jan 12, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Noisy Wine Fridge
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Dec 15, 2008 | Danby DWC283BLS Wine Cooler
My ac compressor suddenly stopped working. It makes a horrible sound like its not turning. Could this be low freon not allowing it to turn on, or the compressor is finished??
Hi there,if it is making a mechanical grinding or any other loud noises,its finished.Does this have rear ac.If it does,there is a design flaw on some years.The rear suction hose(rear evap core to compressor)bypasses the drier.This allows some moisture to make it back to the comp.I hope this was helpfull..Good Luck!!!
Aug 04, 2008 | GMC Yukon XL Cars & Trucks
Danby 22in dishwasher isnt getting enough water
There are a few things to check. 1. Do you have enough water pressure in your lines? It may not be filling enough. 2.Is the washer balanced? Try making sure that its on a level surface. 3. Make sure that your hose isnt kinked, and check the back in the screen to make sure it isnt clogged. 4. Is it above the height of its supply? If so, try finding a lower space to put it on. 5. Take a cup or two of vinegar and run it through a cycle. 6. make sure that, in the arm, there is no clogs or food. I'm not 100% sure what the problem is, other then its not pumping water into it at first and sounds like its blocked some where down the line. If you've never cleaned it with vinegar before, I'd imagine that would be the problem. Hope this helps
Sep 20, 2007 | Danby 22 in. DDW396 Free-standing...
Danby Silhouette DWC512BL Wine Cooler Logo
520 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
jdthefixer
jasbo
jasbo
Are you a Danby Furniture Expert? Answer questions, earn points and help others
