Clarion CDC1255z 12-Disc CD Changer Logo
Posted on Jun 12, 2010
Clarion 12 Disc CD Changer Model # CDC 1255z What
Clarion 12 Disc CD Changer Model # CDC 1255z What does a ERROR CODE 6 message mean?
Anonymous
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Jul 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
14672
Points
63
Out of focus.
if all of your discs have the same error code 6, it is optical lens problem. have it checked to the nearest service center.
Dcz625 has error 6
Q3 ERROR CODES - WHAT DO THEY MEAN? A3 Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
Error 8.Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9.Weak RF. Try alternate frequency
NO CD.CD error message. No CD is magazine or no magazine in CD Changer.
Clarion DCZ625 Owner Manual
Good luck.
Semper Fi,
Z
Jaguar Clarion CD Error code E5
google jaguar clarion cd error code e5
1helpful
I hav a clarion auto cd/stereo displaying err 6 please explain, thank you
For error code 6:
Try an original purchased cd with no scratches and see if the cd player reads it. If yes then lens is dirty or tired so try using a cleaning cd(has little brushes on it). If it doesn't read with the original cd try using the cleaning cd and if no go then look at purchasing a new cd player!
I had a Clarion 6 Disc CAA-355 in my car which got wet and is no longer working. Can I buy the same model again. If so where from and for how much or is there another model that will be compatible with my...
Great Clarion Disk Changer, 6 CDs CDC-655Z:
CDC655z Multi-Disc Changer - 6 -disc direct load mechanism. - 1-Bit D/A converter. - 10 sec. read ahead memory to prevent interruptions caused by shock and vibrations. - Non-stop play. - Optical Digital Output. - 0º to +90º mounting angle.
Great Multi-disk player. Works only with Clarion audio source units.
Selling b/c my deck player broke- I can give you the deck- maybe you can fix it. The model is DXZ-535, comes with owner's manual and remote.
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
CDC-3 magazine will not eject nor play, error on receiver indicates magazine error
1998 porchea boxter cdc-3 cd changer, The cd changer keeps on changing tracks as if their are no cd's in the changer. keeps going from 1 to 6 and then changes to radio.
Car MP3 player error
I believe that error 6 means incompatable disc format or disc read error.
Clarion arx9270 error
Typically means the CD is stuck, has a reading error, or the magazine is stuck. If jammed, you'll have to clear the stuck CD which may require disassembly. Try removing power and rebooting.
If all else fails, I recommend contacting a local car audio professional, or you may contact Clarion customer support directly by clicking here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information has proven beneficial.
Old clarion 1998 cd changer
what head unit is it and what changer are you useing?
2helpful
4answers
CDAC ER2
CDAC ER2 usually means a cd is stuck, not reading properly, or that the magazine is stuck or broken. take out all cds and try it with a known good cd (one that played ok in the past). if that doesn't work, try unplugging the unit and plugging it back in.
if it still doesnt work, take the magazine out, power it up so that you get the "no mag" error, then insert the magazine with no discs and see if it still errors out with ER2. if it does, then the magazine is bad, or the changer is bad..
if it works, then try the known good disc again, if it works now, your magazine was probably stuck, or one of the other cd's isn't liked by the changer.
hope this helps,
trin
Top Clarion Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
