Question about Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera
My camera is saying lens error restart camera when turning it on. Its not letting me access functions. How do I restart camera?
Andrea Lock
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 09, 2011
1 Related Answer
Anonymous
  • 256 Answers
SOURCE: Lens Error. Restart Camera. Camera gives this error message and then shuts off. I can't access photos or function buttons. What can I do?
Press the "MENU" button and navigate to the reset command and reset the camera. That may get the camera to function properly.
Posted on Jun 13, 2009
My cannon lens is jammed and will not open at all keeps saying lens error restart camera but howwww :(
What model are you using?
Also, it is likely you are experiencing a mechanical fault. If your camera is under warranty, it may be best to take it to a shop for service.
To restart the camera, power it off, and remove the battery. Let sit for a few minutes, then replace battery, and turn on.
Remove memory card, and try doing a complete reset (if such a function is available from the menu).
May 06, 2011 | Cameras
Camera wont turn on anymore. it says "Lens error,
Good day,
This is a common problem and sometimes can be fixed.
Please see details on my tip on how to fix this error here:
http://www.fixya.com/support/r7041378-digital_camera_lens_problems
Let me know if my tip was useful for your problem!
Regards
Jan 03, 2011 | Canon PowerShot A1100 IS Digital Camera
May 10, 2009 | Canon PowerShot SD1000 Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
I receive ''access'' error
The "Access" will stay there until your camera passes it's self lens test. The test runs 3 times, then gives up with an error message. The cause of this problem is most likely a grain of sand somewhere in the lens. Only a camera tech could possibly ever hope to find it. Replace the camera lens.
Nov 12, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Canon powersho SD750, restart camera
Hi
Your lens is defective needs to be cleaned, repaired or replaced if you are seeing an error message that reads "E:18" or "Lens error, restart camera" or something similar. Turning the camera off and back on again will not fix the problem unfortunately.
There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know this because I own one that charges a reasonable price to do the repair! (Google 'darntoothysam')
Just let us know if we can help! Good luck from
Darntoothysam com
Thomas
Oct 04, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens Error, Restart
Nikon System error help????
Sep 05, 2008 | Nikon COOLPIX L12 Digital Camera
Lens error
The lens on my canon camera power shot A430 wont open and when I try to start it is says lens error restart the camera
Aug 04, 2008 | Canon PowerShot A430 Digital Camera
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
This soluction not working
Hi REYPERLA
I`m afraid resetting the camera will not work. The camera has a lens problem and is therefore giving the error.
Contacting your nearest Sony service centre is your only solution.
Sorry about the bad news : (
Dawiem
Oct 18, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera Logo
1,027 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
halotheracer
halotheracer
Are you a Canon Camera Expert? Answer questions, earn points and help others
