Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Why the white spots on my tv screen. started with one, then two and now up to 9
Posted by shirley love on
BONES420
  • 171 Answers
The reason this is happening and the problem is getting worst is because the DMD board is starting to go bad some of the micro mirrors are getting stuck on the on or off position and the problem is only going to get worst if you want to fix this problem you need to replace the light engine here is a link that will teach you about this projection works
http://www.howstuffworks.com/dlp2.htm
Posted on Aug 26, 2010
Azrael SRL
  • Mitsubishi Master
  • 11,800 Answers
In a DLP rear projection tv like yours the image is generated this way: a bulb generates the light - the light is projected on an array of tiny mirrors that reflect the light towards a set a of lenses and from there3 to the screen. Those tiny lenses can move so they reflect more or less light - this way the image is created. In your case some of those mirrors have stopped working so they continuously reflect all the light that falls on them - the white dots you see.
The array (DLP chip) is dying, can't be fixed and must be replaced - it will be expensive.
Posted on Jun 12, 2010
5 Related Answers
Anonymous
  • 105 Answers
SOURCE: I GET WHITE SPOTS ON MY LCD SCREEN
this is a touchy subject for sony. basically sony has increased the brightness levels for the backlights to have better color tones in thier lcd's. well the downfall of this is the white spots you are experiencing. this is not a defect, you will never get them to go away, the only thing you can do is to turn the backlight and brightness down to reduce the white spots. if you contact sony, there is a software upgrade that will help reduce this issue...
Posted on Oct 25, 2007
Anonymous
SOURCE: A small white spot on LCD screen TV
buy a new glass lens
Posted on Mar 19, 2008
Anonymous
  • 184 Answers
SOURCE: white spots on screen and growing every day
If these spots are small, they are likely the visual effect of a failing DLP chip. When some of the tiny mirrored surfaces on the chip stop moving, this is the result. This is not something you can fix yourself. A Samsung authorized service center will charge $400-$500 to replace it for you.
michtech
Posted on Feb 18, 2009
callmechaz
  • 15 Answers
SOURCE: white spots on TV Screen
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">DLP/mirror chip is going bad. A common problem on Sammy TVs after 2-3 years. Chip is user replaceable (try samsungparts.com or ebay) for about $150-200. Sammy was (last year) repairing the DLP White Spot problem for free. You MUST talk to ECR (executive customer service) to even think about getting that consideration--forget the standard CS people. Don't know if they are still covering this out of warranty in 2010.</span>
Posted on Aug 21, 2010
SD Tech
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi DLP TV wd-73734 HAS WHITE SPOTS
Bad optical light engine, most expensive part in set
Posted on Dec 10, 2012
There is like haze spot
LCD Panel White Spot Cleaning Technique - YouTube
? 4:13
https://www.youtube.com/watch?v=0OzjLMKFYk8
Jun 9, 2012 - Uploaded by joegingCA
Simple Technical procedure on how to remove a white spotproblem of an LCD Panel. ... Don't like this video? ... How to remove liquid spots from LCD screen - Duration: 5:16. ... Building a liquid crystal display (LCD) - Duration: 13:49. ... 2:18:17. Samsung/Mitsubishi/Toshiba DLP TV Repair - Black & White ...Missing: 170s4fb ‎haze
LCD TV - Problem with white glow seeping in from edges - MyBroadband
mybroadband.co.za/.../349324-LCD-TV-Problem-with-w...
MyBroadband
Jul 12, 2011 - 15 posts - ‎9 authors
Results 1 to 15 of 17 ... After googling it seems this is quite a common problem withLCD panels, though I .... Earlier this year I read that Philips have sold off their LCD TV... Yeah, something like that, unless demo stock is treated differently? ... bleeding from the edges as well as in the middle of the display.Missing: 170s4fb
How to Fix LCD Monitor Ghost images - MadeByMark.com
Jan 14, 2016 | Philips 170S4FB 17" LCD Monitor
I have a 60inch 1080p big screen Mitsubishi tv with atleast a 1000 little white spots and tv turns off frequently when 1st turned on what is wrong?
The white spots sound like the Optical Light engine has a bad display, they sometimes start with one or two and multiply.
The engine is about the most expensive part in the set, see attached photo of one
Dec 21, 2012 | Televison & Video
Why is my Samsung HL-T5076S is starting to have a small white spot in the picture in the middle of the screen?
1) test the CRT, and Hv rectifier, and flyback.
see the diagram attached.
God bless you
Jul 06, 2012 | Televison & Video
My screen is showing white spots (pixel size) How do get rid of them
On a WS-73735 the white spots usually mean a failing or damaged optical light engine.
It is a major part----Google the model number with "problems" or "light engine" etc.
Jun 10, 2012 | Televison & Video
Small white dots are emerging all over my Samsung DLP TV - 46`
Bad Light Engine,Call UED for price of rebuilt one!
1-800-648-6657 TIP if you have never replaced color wheel,they 9/10 go bad also!
Sep 28, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White spot..
Yes, if you order NEW screen starting price 500.00 .
Aug 09, 2009 | LG RU-52SZ51D 52" Rear Projection...
Olevia TV white spot on screen
U should not get such type of white spots on the screen
call ur experts..
thanks..
Feb 01, 2009 | Olevia LT37HVS 37 in. LCD HDTV
SPOTS ON MY PROJECTION TV
LCD pixtel failure. No repair, only replace
May 09, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
632 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
