Question about GE GSH25JFR Side by Side Refrigerator
My refrigerator warms up then eventually the freezer stops freezing too. When I unplug it for a day there is lots of water on the floor and then when restarts it is fine for a couple months when same thing occurs. I don't see ice in the freezer compartments but maybe ice building up between where I cannot see it? Cool air cannot get to refrig?? The automastic defrost not working? Old refrig is it worth repairing??
Posted by tjferguson on
D. Floyd Kolb
  • GE Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorMy refrigerator warms up then eventually the - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 12, 2010
We have got water coming out at the bottom of the freezer of our fridgidair FRC170FF how do i fix it?
1. Your freezer may be not cold enough so water does not freeze.
2. Your freezer may leak so warm air goes into the freezer and keep the temperature higher than freezing temperature.
Jul 03, 2014 | Miele KFN8762SDED Bottom Freezer...
WATER FREEZES ON THE BOTTOM OF THE FREEZER
I have an LG armoire style fridge/freezer and it had lots ice in the bottom and would eventually drip onto the floor. The problem was with the defrost controller. The moisture that enters the freezer when it is opened condenses and freezes on the freezer coil/fins. There is a heating element that sits under this coil which gets turned on by the defrost controller to melt the frost/ice. As the frost/ice melts it drips into a metal tray which channels the water to a drain hole to have it drop into the drip tray underneath the unit for it to evaporate. The problem is that the before the water has time to leave the freezer, it freezes thereby plugging up the drain hole and thus causing subsequent defrost cycles to have the water flow into the bottom of the freezer where it freezes. Eventually the bottom of the freezer fills up with enough ice for the melted water to flow onto the floor. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
When I had the problem and started diagnosing it I opened up the freezer, pulled out the racks, draws, and eventually the door. Then I removed the ice maker and then a few screws and carefully removed the back white wall panel disconnecting the fan and any other electrical connections. Behind the panel you will see the cooling coil/fins, the heating element, the drip pan, and drain hole. Most likely you will see a sheet of ice everywhere. The best way to remove the ice is to boil a bunch of water in a tea kettle and slowly pour it on the ice to get it to melt so that you can start breaking out the pieces. Have a sponge and bucket ready to remove the water as the ice starts to melt. Eventually you should get all of the ice removed and get the drain hole unplugged. After all the ice is removed, you still need to fix the real problem by replacing the defrost controller, using the paper clip trick, or both.
Sep 22, 2009 | Maytag Refrigerators
GE side by side leaks water from icemaker tube
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Kenmore 106.71299100,water freezes on floor of freezer,drain line freezes,I have opened drain with hot water etc.then problem returns in about one month. the refrigerater is 6 years old and this problem is...
You have a partially plugged drain, causing water to flow too slowly. Try reaming out the drain with a long stiff wire until water flows thru it like a faucet. You may have to unplug the unit for a day to get every part warm enough. Hope this helps!
Jan 28, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Refrigerator condensation
I have a Kenmore Coldspot Model 70262990. When I get wet shelves (water, not just condensation), I was able to trace my source to the cold air vent from the freezer. In my case, the water melts from the evaporator and collects in the rear lower section of the freezer. It is "supposed" to go down the drain tube. However I had the drain hole freeze over. Then additional water from the defrost cycle would accumulate in the freezer floor (under the plastic floor) and eventually find its way down the cold air vent between the freezer and refrigerator section. You'll need to unplug the unit, take the plastic floor out of the freezer, remove the evaporator panel to access the defrost drain, melt the frozen water (hair drier works nice), and remove all the water (towel/sponge & bucket). Make sure the drain is not frozen and not blocked. Then put it back together and plug it in.
Does anyone know how to stop the drain tube from freezing over?
Good luck.
Mar 11, 2008 | Refrigerators
Fridge/freezer warm, no fan, light's on
you can remove back cover feel the compressor, is it hot?? perhaps it overheate.
Feb 24, 2008 | Refrigerators
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Water Pooling and freezing on floor of freezer
most likely you have a frozen drain in the freezer section so that whne your refrig defrosts the water runs out into the freezer compartment instead of the drain pan underneath. the fix is to flush the drain with warm water to clear the obstruction. the drain can be reached either by removing the cover in the freezer area or by back flushing the line from beneath the refrig.
Dec 10, 2007 | GALAXY Microsystems 25.4 cu. ft....
GE GSH25JFR Side by Side Refrigerator Logo
476 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
geob91
