This morning our electrolux ewf1481 started walking across the floor on spin cycle. Looking at it the door seal has become twisted.
This sounds as if one of the top spring hangers has come out of its location point.If you turn off the power and remove the top lid,then look into the machine you may still see one spring connected and the other one may have fallen into the base of the machine which you will have to retrieve and refix,by lifting up the drum and resitting it in the hole at the top.Check also that the rear counterbalance block if fitted and the front one have not come loose and the bottom struts are ok.This fault can occur after an uneven load has been in the machine.Some of the Models have a keep plate fitted to stop the springs from un - seating.
You can then inspect the door seal for any damage.
Hope this helps.
Posted on Jun 13, 2010
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a loud screeching noise during the spin cycle on your Electrolux washer. You will hear a certain amount of motor whine during the spin cycle this is a normal operation of your appliance. -Matt
