Question about Samsung SGH-A877 Impression Cell Phone
My samsung sgh-a877 wont calibrate correctly. The touch screen is messed up. I tried several hard restores, nothing will fix this, supposedly. Calibrated several times, as well. It keeps getting worse. Aim is off and sometimes wont recognize that I have clicked at all.
  • Samsung Master
  • 624 Answers
Sir i tried and tested it in chinaphone ,lets see if it also works in samsung...press power key and # , if not works insert a working sim and send message to that sim ...if the phone received the message it will automatically calibrated thanks and goodluck
Posted on Jun 12, 2010
Touch sensor not working
If your touch screen is not working, theres just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated.
If you can access the menu of the phone, i will advice you calibrate the screen first before you send it to a repair shop. There is no updates to download for such problem as updating the firmware of the phone would do nothing but change the settings of the phone.
To calibrate the screen, you will have to go to the phones menu, go to settings, then you select the calibrate screen, it will show you some stars to touch and once you touch them properly, then your screen will be able to work effectively.
But if you cannot access the menu because of the touch, then i will advice you send it off for repairs, and what to repair on the phone is the sensor board.
Hope this helps you.
Jul 18, 2011 | Samsung SGH-A877 Impression Cell Phone
WHAT WANT TO KNOW WHAT IS THE PROCESS TO UNLOCK THIS CELLPHONE
To unlock your samsung mobiles with codes are the best one, because it is easy & safe also,
Follow the instructions :
Warning : Do not enter any wrong unlock codes on your Samsung SGH-A877 Impression mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-A877 Impression mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung SGH-A877 Impression with a NOT ACCEPTED SIM Card.
2 - Samsung SGH-A877 Impression will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-A877 Impression shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-A877 Impression.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-A877 Impression is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-A877 Impression.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung SGH-A877 Impression.
Get the unlock code from this site http://www.theunlockspot.com/samsung-sgh-a877-impression/rs10wp9/ to your samsung mobile........
Jun 12, 2011 | Samsung SGH-A877 Impression Cell Phone
The calibration on my samsung impression was way off so i used the unlck code *2767*3855# the phone shut down and restarted and at the calibration screen tapped the center of cross many many times cross...
OK..your touch screen was jammed or not working and you did reset via code *2767*3855# then the phone restarted with the calibration cross....you tapped the cross but nothing is happening.......what to do? first shutdown the phone remove the battery for 30 sec also remove the simcard put the battery again start the phone when the calibration screen pops up tap on the cross here you must feel the tapping is working by feeling a light vibration of the phone.....then tap on the lower bar of the screen which has color (light gray) different than the calibration screen the cross will move to another corner......repeat this for all four corners then you should see and OK on the bar to save and exit to the normal screen........done
Jan 03, 2011 | Samsung SGH-A877 Impression Cell Phone
My Samsung impression wont let me calibrate it. It vibrates when i touch the cross but nothing else happens
To be honest if you are just now aquiring this phone I would take it back to your celluar provider and show them what's going on and they should give you a new one.[This happens alot.] This small glitch also leads to larger glitches.
Nov 07, 2010 | Samsung SGH-A877 Impression Cell Phone
WHen I touch contacts, dial or menu nothing happens. When I go to my call list and touch a contact it opens the contact 3 or 4 rows up.
try and reset the fone's calibration.. go to settings and in their check phone settings u will find a thingy called calibration select it and follow instructions...
Sep 02, 2010 | Samsung SGH-A877 Impression Cell Phone
I cant acess my setting to calibrate my phone. When i touch the menu button it acts like Im touching the center of the screen. When I try to dial the number using the touch screen it doesnt dial the number...
Ok there might be a battery issue. Or there might need to be a touch calibration reset. To do that go to your settings and select touch calibration and do it again.
ALSO IF YOUR PHONE IS STILL IN WARRENTY AKA WITHIN 1 YEAR OF PURCHASE THEN CALL 1800 801 1101. THEY WILL HELP YOU. YOU WILL NEED YOUR IMEI NUMBER OFF THE BACK OF THE PHONE. IF NOT CALL THE INSURANCE HOTLINE WHICH IS ON THE AT&T WEBSITE.
Jun 24, 2010 | Samsung SGH-A877 Impression Cell Phone
Samsung sgh-a877
Sounds like your phone has a digitizer if the touch screen is not responding.you can purchase a digitizer on ebay, they cost anywhere from $9-16 and if you are in the U.S you can send it to us to fix it for you for a reasonable price.
http://shop.ebay.com/i.html?_nkw=+Samsung+SGH-A877+digitizer&_sacat=0&_odkw=C113+unlock+code&_osacat=0&_trksid=p3286.c0.m270.l1313
Jun 10, 2010 | Samsung SGH-A877 Impression Cell Phone
My samsung impression a877 (cell phone) touch screen stop working please help me with some solutions thank you so much!!!!!
first of all take the battery out for 30 secs the reinsert ....next go to settings ...screen ...re calibrate and see if that helps
May 17, 2010 | Samsung SGH-A877 Impression Cell Phone
Samsung SGH-A877 Impression Cell Phone Logo
1,188 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
John Tripp
John Tripp
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
