Manual convergence should fix the problem if it does not the set most likely either has a bulb burnt out or a bulbs power / focus needs to be adjusted by taking off the panel and finding a 6 screw control panel
should look like that 3 screws in a row on top of another three screws each of thees control the power and focus of each color this is a somewhat delicate process and is a huge pain on larger tvs that you cannot completely see the picture or color while you are directly under in front of it so I had my gf come in the room and sit across to let me know which color was doing what if you dont have someone you will need to check after each adjustment
now the diagnostic
as i said each screw controls a colors power and focus the focus is used if you see an outline of a color around pictures if everyone looks like a dead jedi with a blue aura around them the blue focus needs to be adjusted and so on for each color if you skies or blue screens seem feint your blue power probably needs to be turned up and so on for each color
if through the course of this you can see the bulbs and notice one is out your probably looking at dealing with the color issue until the time you can purchase a new tv as the cost of the bulb and the technician needed to install it as they are wired to a circuit board and requires technical knowledge and tools
hope this helped
Robb
