Question about Memorex Audio Players & Recorders
I have had a Memorex 9299M AM/FM Stereo, Double cassette, turntable, stereo aux in jack, and 3cd changer for about 4 years now. For some reason, about 3 years ago, it stopped recognizing that there were cds in the player... which was very annoying but everything else still worked. When I moved about a year ago, the entire machine stopped working. It almost looks like the Power/Stand by button is stuck in the stand by mode. I tried unplugging the system hoping that would unstick it, but that didn't work either. I've looked for my user's manual but can't find it.
Posted by faranya2 on
Joe Hogan
  • 10,865 Answers
Hello. Sorry for your troubles. truth is this bad boy is not worth fixing. The new ones are inexpensive, better, lighter, smaller, under warranty. better sound. digital. need i say more. Joe
Posted on Jun 12, 2010
  • faranya2 Jun 12, 2010
    Well I would ditch this one if I could afford to get another one, but I can't so I've got to figure out if there's something that can actually be done (beside drop kicking it off the balcony). What do you think is the problem?
  • mamalove2 Jul 02, 2011
    I have the same problem. My system just stopped working, also. Would not even come on.
How do I clean the laser on a Memorex CD mini stereo with a 3cd changer
It is not even sure your laser is dirty. Perhaps you only have some bad CD's?
Does it also skip, with real music CD's. I mean the ones that are not burned in a computer. Not all self mad disks are good enough to be played and not all players can handle the self produced disks.
The cleaner you could use, is a CD, with a little brush glued on it. Don't try to make one, just buy one.
See the little red bus to the left of the middle.
Nov 18, 2014 | Memorex Computers & Internet
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 | Apple iPod touch
I want to connect my ipod to the radio
According to Apple, over 90 percent of new cars retailed in the United States are equipped with iPod connectivity.
The iPod has become such a popular device, that many car stereos are now furnished with a 30-pin dock connector cable in order to link to the portable media player.
But this built-in compatibility is not essential for connecting your iPod to your car stereo. In fact, there are numerous options for integrating your iPod with your car.
Recently manufactured vehicles can support an iPod connection through an auxiliary input.
And FM transmitters can be used to stream your iPod's audio files through an FM frequency. iPods can even be connected to much older car stereos with the use of a tape adapter.
Connect an iPod to a Car Stereo Through the Auxiliary Input
Insert an extension cable with 3.5 mm stereo connectors on each end into the headphone output of your iPod. Insert the other end of the 3.5 mm stereo connector cable into your car stereo system's auxiliary input. Press the "Aux" button on your car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With an FM Transmitter Insert the FM transmitter into the 30-pin dock connector of your iPod. Turn on your iPod to activate the FM transmitter. Select the FM frequency you want your device to stream audio to on your car stereo. Turn on the car stereo and tune it to the same FM frequency as the FM transmitter attached to your iPod. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With a Cassette Adapter Plug the jack connector of the cassette adapter into the headphone output of your iPod. Insert the cassette into the car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod.
http://www.apple.com/ipod/car-integration/ http://www.pcmag.com/article2/0,2817,1865467,00.asp
Feb 10, 2013 | Apple iPod Audio Players & Recorders
I have a Memorex 9200M am/fm stereo ,double cassette turntable and 3 cd changer and it will no turn on, I've only used it 8 or 9 times. How or can I fix it ?
If you bought this new, I strongly suggest taking it back. There are no servicable parts inside and taking it apart will void warranty
Mar 04, 2012 | Memorex Televison & Video
Aai have the following AKAI Audio Stereo System and no Idea how to connect them. Please help Akai Model AP-D210 turntable Akai model CS-F14 Stereo cassette deck Akai model AT-K110 Fm Am Tuner Akai...
In general, outs to ins.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
Don't use excessive EQ.
Mar 17, 2011 | Akai Audio Players & Recorders
Volume Level on Memorex 9299M 4-in-1 Turntable System Way Too Low
It's the nature of the all-in-one turntable beast to be low fi and low performance. Too much volume and vibration would feed back through the turntable.
It does have a Line Out that you could slave over to REAL electronics and speakers.
May 23, 2010 | Memorex Nostalgia Turntable and Stereo...
How do i connect an ipod in a car
hi,
you connect your i-pod to the car stereo using 3.5mm stereo connectors on each end. If your car does not support stereo input in the aux(or if it does not have a sound input jack), then you can also use the cassette adapter. Or if you have a 30 pin connector, your I-pod is recognized immediately. i have attached an image showing my car with i-pod.please rate my solution as helpful.
Apr 02, 2010 | Apple iPod MA446LL/A MP3 Player
Kenwood Stereo
I presume you realize none of these things produces speaker amplification. A receiver would do that and facilitate graceful and simultaneous interconnections. But it's not a necessity for selective interconnective between them, just not all at the same time.
I can't find any details on anything you named except the Tuner.
Typically, the tuner would use an RCA pair to go to a receiver AUX, TUNER or other Line Level input for source selection and amplification. Lacking a receiver, run it to the Tape Deck inputs for recording.
Ditto for the CD changer, but you'll probably have to disconnect the tuner.
Jan 26, 2010 | Audio Players & Recorders
I have a memorex stereo, turntable, 3 cd changer etc. The standby light comes on but no sound, it is only 2 yrs old..
Sometimes you have to unplug it for about 30 seconds, then when you plug it in press the power on button. If there is still no sound, check the speaker connections on the back they sometimes come loose.
Oct 17, 2009 | Electro Brand Nostalgic Stereo CD Music...
738 people viewed this question
Top Memorex Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Paul Bade
Carlo Barzo
Carlo Barzo
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
