Question about Canon PIXMA MP160 All-In-One InkJet Printer
Although different scanner has different option still I am giving you the general method of scanning.
Put the photo on the scanner (photo face down touching the glass of the scanner) - look the cover is perfectly placed and no light is entering inside of the scanner. Now run the scanner software - select scan item as "Photo" (other options are text or documents etc), select the option "Color" (other option is Black and white or gray ). Select the resolution more than 200 dpi (more dpi will give better output), give path where the file will be saved after scanning or keep it default, choose the file type JPEG is better (other options may be BMP, TIF etc). First you get preview - look the expected scan output - if required you adjust or lace the photo on the scanner better way - then again get preview - if you are satisfied you may select the portion out of the whole preview page for scanning - now click scan. It will give JPEG file in the specified location.
Posted on Jun 12, 2010
