Question about eMachines (ET181001) (A1803181 ON) PC Desktop
EMachines ET1810-01 trying to install xp pro on clean hd, cmos does not show hard drive and xp says there is no hd. it is connected. how do i get it to find the hd?
Posted by James Huddleston on
Andrew Chrostek
    Guru:
  • 178 Answers
You need to format your hard drive. Set your boot device to cdrom in your bios. Boot using xp cd.DO a reinstall of windows and it should give you the option to format or delete partitions on your hard drive. if that doesnt work try putting the hard drive in another computer to see if it works. Or you can buy a hard drive enclosure that allows you to use your hard drive as an external device.
Posted on Jun 11, 2010
This Emachine will not boot from HD or CD. The screen only says Emachine.
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter check to make sure the first boot device is set to your hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
you can change it to cd if you want to install an operating system
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure the CPU central processing unit has thermal paste and dust free and is securely seated
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps
Apr 22, 2012 | eMachines T1440 PC Desktop
Emachines D4362 starts only after many button pushes
Sounds like you might have corrupt window system files or the machine might not be recognizing the hard drive.
Press the DEL button to go into the BIOS. Go to the section that shows you the hard drive. If it doesn't show you a hard drive model and shows none then your hard drive is bad and would need to be replaced. If your hard drive is recognized in the BIOS then you'll need to try and reinstall windows. If you can't get windows reinstalled then the hard drive is bad at that point as well.
Jan 18, 2012 | E-Machines eMachines Desktop PC
Emachine T3304 comes blue screen, windows would not turn on
Mamum23 if you install windows xp pro and the problem persist it could be a few reason like: 1. Have a hardware that is interfering with the boot (printer, external HD, etc) 2. Could be the hard drive that is having problems in a few sectors (blocks) and you may need a new HD. 3. Could be the modemboard slots but that could be really rare. If I was you I made the troubleshoot 1 and then 2.
May 06, 2010 | E-Machines eMachines Desktop PC
WD Caviar SE16 WD3200AAKS 320GB 7200 not recognized at install
Windows XP does not have built in SATA drivers. You will need to download the XP drivers from Western Digital's website and install before the computer will allow you to format and use your new drive. Hope this helps.
Jul 18, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Emachine cant find operating system
If it doesn't show a HD in bios, that means that either the HD isn't connected properly ie you have 2 devices set as slave or master on same ide cable and it cant detect the HD. Try temporarily disconnecting the CDroms or other devices that may be conflicting and see if that helps.
Hope that helps. Please remember to rate this information.
Thanks
May 03, 2009 | Computers & Internet
Hard Drive Install gone bad!
Unplug the slaved hard drive.
Restart the computer. If you get the same results.
Pull out the cmos battery on the motherboard. Most look like shiny nickles, be carefull not to damage the board. Make sure you unplug the computer first and let it sit a minute or two afterwards before putting it back.
That will set the bios back to defaults and you should be able to get the computer up and running from there.
As far as slaving that drive to be used as extra storage, you might want to consider an external enclousure instead.
Best of luck.
Feb 24, 2009 | eMachines T3406 PC Desktop
160gb samsung sata II
The PC is not seeing the Hard drive. check the jumper pin for the setting on the hard drive. If you have one HD then it should be set to master or cable select. Reboot and the cmos will see the HD. If not check the cables, and last check to see if the controller driver is installed for the motherboard. The controller is where the cable connects.
[email protected]
Aug 21, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Keep getting cant read disk reboot
The message "can,t read disk" is indicative of a defective hard drive in the eMachine. In most instances, this refers to a hardware problem and can only be corrected by replacing the defective hard drive and re-installing the Operating System as well as all other software/applications. This can be verified by entering the CMOS/BIOS set-up and trying to manually detect the HD. If it even manually detecting and the HD will not show up, then the defect has been confirmed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 25, 2008 | E-Machines eMachines Desktop PC
Need boot load for emachine T2484
Hi, You need to enter your CMOS/BIOS setup and set your "First Boot Device". Immediately after powering up, press the "Del" key, display will show CMOS/BIOS settings. Verify that all your hard disks are being detected/recognized by your PC. Thereafter, set your First boot device to your new HD. Save and Exit. Hope this be of some idea/help. Post back how things are or should you need additional information. Good luck and kind regards.
Sep 30, 2007 | E-Machines eMachines Desktop PC
eMachines (ET181001) (A1803181 ON) PC Desktop Logo
234 people viewed this question
Top eMachines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
