Question about UTStarcom Blitz Cell Phone
My phone doent power on without its charger connected
How can i turn power on my phone without using a charger?
Posted by miniskater20 on
  • Anonymous Mar 16, 2014
    Well I left my zte phone on the table and one of my baby cousin dropped it hard on the floor and well my power button came off and I can turn my phone on without being on the charger
Gary Wurzinger
    New Friend:
  • 92 Answers
It is time to get a new battery for your phone.
Posted on Jun 11, 2010
Why does my Nokia phone say "charger not supported?
That error message usually occurs when using an unsupported third party charger. An example would be if you bought a cheap "knock off" charger that doesn't supply the correct voltage to the phone. These messages can sometimes occur in error when using an official or supported charger.
If you're sure you're using a supported charger, there is something you can try to fix this error. First, unplug the charger from the phone and the power outlet. Turn off the phone and then remove the battery. Wait about 15 seconds and insert the battery again. Turn on the phone, and plug in the charger to the power outlet and the phone. The phone should now charge.
If it's still not working, you'll need to try to get a new charger. Sometimes, if the phone is still in warranty, you can get the charger replaced for free if it is defective.
Jun 01, 2011 | Nokia 2626 Mobile Phone
The screen on my phone went completely black and will no longer turn on from what iv tried i cant hear or seen anything and there is no sighn of water damage what do i do?
I will try and keep this short. I have a Motorola Razr (puchased in the USA..... this will make sense later) and I lend it to my brother when he visits me from Canada. (Roaming charges for Canadians using their phone in the US is insane) He too has a Motarola phone that he brought with him. The Charger that he brought with him was for a Canadian phone. Apparently, you cannot use a charge for a Canadian phone, on a USA contracted phone..... I'm not sure why, but it is the case. He attempted to charge my USA phone with his Canadian Charger and the screen went blank. The phone was still on and could even receive calls. Even when the calls came in, the screen still remained blank. I won't bore you with any more details.
Here is how I fixed it:
- Unplug phone from Canadian Charger
- Take the battery out of the phone.
- Plug in USA built charger (without the battery in the phone)
- The phone attempt to charge
- Screen should turn on. Wait till screen indicates (Cannot charge battery)
- Plug battery in.
- Hold down power button to turn on the phone.
- Phone should be in working order.
I don't claim to be an expert. This may only apply to my particular situation. Hope it helps if you happen to use the incorrect charger. Take care.
Mar 22, 2011 | Motorola Mobility RAZR V3
I want to format my mobile
  • On some forums it is reported that you can make your NOkia 97 work smoothly (after a crash) without formatting it;
  • Turn off your phone
  • Connect the charger
  • Remove the charger when the screen lights up and wait until it goes off.
  • Turn on the phone immediately after using the Power button on top.
  • After the vibration at start up, plug-in the charger.
For formating follow these Just follow the steps
Make a backup of contacts in your another sim.
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3"
"green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory
stetting.
Hope this helps.
Jan 17, 2011 | Nokia N79 Cellular Phone
Cut off by itself and wont cut back on
After charging it up fully, attempt to turn it on without being plugged into the charger. If it will not turn on, try turning it on while on the charger. If it does not power up and there is nothing wrong with the charger you have a phone issue. If it does power on, you need a new battery.
Mar 27, 2010 | Sprint BlackBerry 8703e Phone
Please,phone won't turn On
Take of the battery and let the phone stand for about 20 min without the charger or battery connected. Afterwards connect the charger only without the battery and see if the phone comes on. If nothing happens, attach the battery and disconnect the power cord to see if it powers up. If that does not work, keep the battery attached, then connect the power cord and see if it powers up. If none of these work, you will have to contact your manufacturer or wireless provider.
Nov 29, 2009 | Nokia 6210 Navigator Cell Phone
Won't turn on without charger attached, but goes blank after
You have a software issue, sounds like it is fried. Call your phone company and get a replacement or exchange shipped out. You cannot fix this manually. Good luck, sorry about the problem
Mar 19, 2009 | Samsung SGH-Z500 Cellular Phone
Nokia charge without battery (Nokia 5310 XpressMusic)
no,charger provides only battery charging and it does not provide the potential difference for the phone to switch on.try with battery of your friends or some one else
Mar 11, 2009 | Nokia 5310 Cellular Phone
When I take my chocolate off the charger it dies and wont turn on
are you using , original charger if yes , try to charge the batry separatly
Nov 30, 2008 | LG CHOCOLATE VX8500 Cellular Phone
UTStarcom Blitz Cell Phone Logo
310 people viewed this question
Top UTStarcom Cell Phones Experts
Marvin
Marvin
L Vincent Testa
L Vincent Testa
Andrew Taylor
Andrew Taylor
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
