All sprayed water comes from the pump located at the lower deck. Remove all parts from the lower spray assembly (note position and orientation of each part) down to the deck. There should be a large filter screen at the bottom that commonly becomes plugged with food and hard water deposits. Soak the screen in a mixture of hot water, white vinegar, and dish detergent for an hour or two until the deposits come free. Check around the pump area and the deck openings for any debris plugging. Reassemble in reverse order, but check all three spray arms for spray hole plugging or split seams. Hope this helps!
