Powers on then off is usually a sign that the battery in the unit is no longer holding a charge, i would suggest that you check the battery and make sure that it is holding a charge and if not, change the battery out, these gps units have a dead circuit in them, if the battery is no good then usually the unit will not turn on, also for testing purposes if you pull the battery then try powering up the unit it may turn on, if this happens then you know the battery needs to be replaced.
A battery place i usually the best bet, someplace like a batteryman or some other place that can rebuild batteries, they will usually have a repair shop. If you still can't find a place try a hobby store, not for the battery but they will usually know of someplace that rebuilds or repairs batteries. Hope this helps
any suggestions for where to take for repairs?
