You've got the best scenario. Open up the oven by removing the appropriate screws, and unplug the power cord of course. Just disconnect the working element and move it over so it uses the connections for the other element. Power things up with just the one element. This will show the working element continues to work in the new position and is a clear indication that you need an additional element.
This could as easily be a problem with a switch or the element. You'll know after testing.
Hi,the problem is either from the wiring that supplies the heater element,it might be burnt,or the heating element is broken or burnt,you have to take apart the oven ,remove the element bracket so you can be able to check and replace the burnt component,
Thanks and take care
My first personal response was the element also, until I saw how the wiring itself ran to each element. I do have the unit apart and I don't see any distinguishable burnt area on the element itself, nor any noticeable burnt area around the switches, wiring, connections, diodes, etc. I just need to be sure I spend the money in the right area, ie; element!
Ed L.
Hi, you can use this repair guide from this link below.
(home.howstuffworks.com/how-to-repair-an-oven.htm/printable).
Take care.
Hi, sorry about that answer.you can use this i think it will work.
(ehow.com/how_112477_fix-toaster.html).
Please stop the rating and just place your comment .
thank you.
Hello,you can also use this link for more in sites.When you get into the site,read through and scroll down and you will see where (previous and next page is) to get to the next page.
home.howstuffworks.com/how-to-repair-small-appliances1.htm.
Take care.
I have a Delonghi toaster oven...model # XU18ST. The top front heater element does not heat up on any of the settings for toaster, bake or broil. All the other three work fine. Could this be a switch problem and not just the element itself? Ed L.
I don't expect my solution to be fixing a full size kitchen oven. This is a counter toaster/oven and my specific question was not answered. Ed L.
