Question about Verbatim CD-RW Rewritable Discs, Branded Surface, 700MB/80Min, 24x, 10/PK, Matte Silver - VER95174 (50023942951747) Media
Can movie be burn in cd-rw?? - Verbatim CD-RW Rewritable Discs, Branded Surface, 700MB/80Min, 24x, 10/PK, Matte Silver - VER95174 (50023942951747) Media
Sam
  • 3,247 Answers
A cd-rw would normally hold 500MB of data. A normal movie would need about 3-4 GB of data. You get programs that would save the movie on CD-RW as a VCD with compression to fit in lesser number of CDs. But you will not find many players that would play the cd-rw with the VCD format movie.
Best to use the DVD discs.
Posted on Jun 11, 2010
Anonymous
    New Friend:
  • 6 Answers
No problem just click this link to download nero
Posted on Jul 10, 2010
Im having trouble with my drives it wont read the cd or burn the cd or dvd
Hello there,
If your LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe does not read disc, burn cds or dvd, then it means there is a problem with the lens of the LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe.
You will have to replace the LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe or have the lens replaced.
Be sure not to use the LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe to watch movies as that weakens the lens easily.
Hope this helped.
Goodluck
Elect_Comp
CDS BURN BUT CANNOT PLAY WHY?
You mean, you burn the CD in your PC but you can't play it in external CD player ?
Maybe you didn't burned it in "movie" mode, just burned in "data" mode. As you know, CD player can't play .avi or .mkv or other video formats. They only can play movie in .DAT format, and when you burn in "make a movie" mode, the burner will convert your movie to this format so you can re-open your movie via CD player.
Or there is an error during the burning time, if this happen then you have to re-burn your movie into another CD.
Hope this help and be kind to rate this answer.
(^_^)
When I burn movies from my hp laptop the movie burns fine, but when i watch the movie on my dvd player it plays fine until 1/2 way and then freezes. What can I do to stop this from happening?
Use a high density CD-R or DVD-R disc not the RW (read-write) ones to sustain quality. Also, when you are using Nero, check the option "Verify Disc integrity" before clicking the "burn" command so that the disc will be verified on its data integrity after the burning process is completed.
1helpful
August 2005, I purchased this powermac g5. There has been a steady deterioration in the DVD player. Presently, no rented DVDs play. SONY DVD RW DW-Q28A: Firmware Revision: KAS7 Interconnect: ATAPI Burn...
OK. The movie industry strikes again! Your RENTED DVDs are the key.Hollywood made some adjustments to prevent the copying of the movies. So they put software to detect the kind of drives in which the movies are inserted. DVD/RW are capable of copying a movie, so they are disqualified as playing devices. Have it be a normal DVD player you won't be facing any troubles.
2answers
Burning movies
Yes. Many burning apps (such as Nero) support the creation of Video-CDs, and most current DVD players support playing these Video-CDs.
When I burn movies on cd's off kodak software the won't ply on my dvs player or my xbox. what do I need to change
NEED TO BURN TO AND CD-RW THAN IT SHOULD WORK FINE MOST OF THEM DON'T READ CD-R'S JUST CD-RW'S
1helpful
HL-DT-ST DVD-RW GWA-4082
ya it ll work... first change the cd to write mode ..hence not able to burn files...
CD-RW and DVD-RW problems
u might not be burning them in the right format. try burning them as a dat file or a dvd/vcd format
ATAPI DVD+RW Burning Problem
DVD / CD-RW is usually a a combo drive
DVD PLAYER with CD BURNER
DVD-RW is a dvd rewritable drive
2answers
CD-RW/DVD-ROM BURNER
if you wish to burn cd's which is your burner then you need a software called nero burning rom or any other burning software that lets you burn data or audio cd's or vcd's to burn with if you wish to burn dvd's then you need a dvd burner combo drive which lets you burn dvds
Electronics - Others Logo
Top Verbatim Electronics - Others Experts
Mandeep  Singh
Mandeep Singh
Ekse
Are you a Verbatim Electronics - Other Expert? Answer questions, earn points and help others
