Televison & Video Logo
John Mwangi Posted on Jun 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On switching shows stdby indicator. horizontal trasistor getting 80v. hav changed capacitor 250v 47uf and 160v 47uf. no change. hav also changed power ic tea1507p plus tank cap 420v 220uf. still not coming on.
Andrea Blove
Level 2:
Sergeant:
Champion:
  • Expert 218 Answers
  • Posted on Jun 11, 2010
Andrea Blove
Expert
Level 2:
Sergeant:
Champion:
Answers
218
Questions
0
Helped
78238
Points
565
Have a professional take a look at it to see whether there is any internal damage.
1helpful
Have a Bryant Pkus 80v. Everything fires up but
Check to see if fan is hot. If it is check capacitor. The silver oval component attached to blower housing. If motor is not hot you have a bad fan board or fan switch, Check above burners and you will see a lower limit switch and above that a fan switch. If you do not see a fan switch. The problem is blower control on board. You will have to replace board. Rus
7helpful
2answers
LG STUDIOWORKS 500G monitor dead ?
your irf 630 is not original purchase it from proper LG authorised service centre it is costly but never become faulty again duplicate mosfet overheats if your green led is on then measure voltage at E.H.T.connect meter at output transister if E.H.T. is producing then meter should show 1 digit if not then 50v will show take care that signal cable should be disconnected if E.H.T. is not producing then check +vcc at horizontal ic it should be 12v. if 12v is not present then check regulator ic 7812 insmps
My kolin tv kct2570 has vertical problem
replace the 2pcs 4.7uf/160v and (474).47uf/400v gud luck :) horizontal area.
from enriz622
2answers
Zenith PVY6067 are there any common Vertical deflection failures I lost approx. 20 % vertical deflection
there are caps that can cause this in the vertical circuit
that will need to be changed to correct this
some one says there are kits available at
tvrepairworld.com for this
2answers
Philips 20ps47s301 turns on then starts clicking and turns off
IT SOUNDS LIKE YOU HAVE A POWER SUPPLY PROBLEM OR RELAY PROBLEM. BEING A 20 INCH SET IT IS NOT WORTH REPIRING. PARTS AND LABOR WILL BE OVER $100.
Bose Lifestyle 5
Changing the capacitance value (33uF) is generally not recommended. As for the voltage, you can always replace a lower voltage cap with a higher voltage as long as it will physically fit.
5helpful
4answers
Kenwood B-B5/B7 Power Amplifier/Graphic Equalizer
Change the Capacitor C110 (47FU 25v) I found this solution on another post somewhere and it has worked on mine too.
No picture or sound after a few minutes, replaced blown C812 but problem returned
Hello to all, I have a tv zenith model C27V36, and it has a problem I connect it in the series and it does not turn on and I connect it to the network(net) and immediately burns (damages) the horizontal exit that is a trasistor C5905 and it burns (damages) both resistances of the protection,I changed the trasistor C5905 for a trasistor C3997 that is 20 amps and nonetheless it burns it,there are no signs of short circuits. Could the problem be the high horizontal ocsilacion?? But since turning it on it burns(damages) the horizontal exit I do not have way of checking it, because it is automatically damaged . can someone please tell me what to do in this case??? Or where I can find an electronic diagram or a sketch??? Or can someone who has worked on this TV before h
help me out?? It is a zenith model C27V36 of 27 "..
thank you for you help.
Black horizontal bars and jumpy picture.
Yes . Some of these caps are in the secondary of the power supply and some are on the signal board around 5v and 7v supply lines on the signal board . The 5 & 7 are mounted on heat sinks and the caps are right around there .Generally either 2.2uf or 4.7uf or the 47uf . Good luck
F32672sb pincushion
The pincushion is something that happens to this particular set. You may have the blue box type Capacitor in this set if not then a more brown or redish orange cap. I believe it is C4401. Most of the time its behind the Horizontal output. The cap gets leaky, most of the time it's a .47uf @250v. Try this, hope this helps
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
