Question about Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo
What is the universal remote code to program a Comcast digital transport adapter (DTA) remote control. I have a Panasonic pv-dm2092 tv.
Posted by cassmail on
Dick Snider
    President:
  • 742 Answers
Ask at manualfox.com/remote.htm
they will figure it out
Posted on Jun 11, 2010
Program remote for comcast
Check these codes: 11144, 11240, 11331
programmmming TVTV control
The Comcast DTA remote control is preprogrammed at the factory to operate the DTA receiver. The Comcast DTA remote also contains a universal TV library to allow you to control the Power and Volume of your TV.
1. Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold Setup until the Red Light blinks twice, then release Setup.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
Jul 16, 2012 | Olevia 227-S11 27 in. LCD TV
Remote codes for Panasonic MODEL# PV-DF2704
5 digit code for the comcast red button silver remote is 21462 this pertains to Panasonic MODEL# PV-DF2704
Nov 20, 2011 | Panasonic PV-DF2703 Triple Play 27 in....
I have a Panasonic pv-c1320 without the remote. trying to get the code through comcast digital transport adapter need a 5 digit code
Here are some Panasonic codes that Comcast lists on their website: 21062, 20035, 20162, 20225,
20614, 20616, 21035
(but the code depends on which remote you have, check Comcast's website for more info)
http://www.comcast.com/corporate/customers/customer_support/remotes.html
You can also try to manually search for the code:
Turn the TV on
Press TV or AUX
Press and hold "Setup" until TV/AUX blinks twice
Enter 9911 and press "Power" using the Comcast remote
Press "Channel Up" until device powers off
Press "Setup" to lock in that code
Please let me know if you found this helpful.
Have a great day!
Mar 16, 2011 | Panasonic PV-C1320 13 in. TV/VCR Combo
Need Comcast DTA remote to control Panasonic TV/VCR combo
Try website 1-800-Remotes Factory original.To buy an exact remote or very close to the original.
Apr 25, 2010 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Remote code for Panasonic TV/VCR combo
Use the RCA universal control programing the code 109 in vcr funtion and will work..... i try and work....
Feb 09, 2010 | Panasonic Televison & Video
Need to program remote, don't have codes
RCA TV/VCR Combo Model T09085:
Comcast Digital Adapter Remote (DTA) Code is... 00000
Comcast Universal Remote - Red OK/Select Button (DTC)
Code is... 21479. This code controls TV On/Off and VCR All functions. I could'n find code for vol+/vol- and mute.
Oct 23, 2009 | Televison & Video
Need TV codes for using the comcast DTA remote
I just went through this last night with combo, similar model. They tell you to use the power off test to see when you've got it - nothing worked for that. Then I tried the Panasonic codes and used the volume control as a test, which is much more important, and I found the 3rd code worked for that. I figured, close enough for me, and better than nothing.
Sep 09, 2009 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
try these codes for broksonic 10236,10463,11911,11938, 10030,11935,11929
Apr 25, 2009 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo Logo
1,229 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
