Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
Several questions here...
1. Is the oil serviced to the full mark?
The oil level sensor can cause a no spark condition because it grounds the ignition.
2. Is there spark at the spark plug? You can remove the spark plug and test for spark but if the plug is internally grounded it will show spark when removed but if it is installed it can still be defective. (Spark Plugs are cheap replace it)
3. Is the handle safety cable loose even when depressed? A bad safety cable or an improper cable adjustment can also cause a lack of spark.
4. Do you note gas on the spark plug or is it very dry? If the spark plug is dry try adding a splash of gas into the cylinder via the spark plug hole and see if you get a temporary / momentary start. If you do then you have either a fuel supply or carb problem.
Make sure the fuel selector is in the ON position.
5. If you suspect a fuel problem disconnect the tank feed line to the carb and see if there is fuel flow from the tank, No fuel flow no start.... then problem in the gas tank or supply line.
I will post this as a solution but will watch for any responses and continue to assist you if needed.
Thanks for using FixYa.
Kelly
Posted on Jun 17, 2010
This reply is not to the asker... but to benji2264. Read the post... the 160cc engine is a Honda.
See Yardman
12B-569Q755 (Self propelled)
and
11A-549Q001
Ok, I'm trying to start the mower and cannot locate the fuel selector....I know this sounds ignorant but where is the fuel selector?
Answer to this post:
On a Honda engine the fuel selector (On / off) is co-located with the choke lever. One above the other with the fuel selector being black and the choke lever being white. If there is a problem your having I can help you. Most hard starting issues are caused by debris in the bottom of the float bowl or the fuel sump under the fuel selector valve. 95% of the time it is strictly in the fuel bowl.
Kelly
Change the fuel, drain the tank remove the float bowl and flush/spray the cab with carb. cleaner in and out, repalce the old gas with new regular fuel, replace the air filter if old, prime the carb. primer ball 5 X's before pulling chord...pull chord and Walla!! Runs like a kitten
Posted on Jun 24, 2010
If the oil is low I have never seen an oil cut out on these engines they are sold at a discounted price over other comparable priced mowers and have a great Briggs & Stratton Engine mounted on the deck usually 6.5 h.p., while it is good to be sure the oil is full and or changed every couple of years it is not anything that will stop from starting, these engines dont incorporate a low oil cut off switch, however if you run the oil too low you can "seize" the engine and that will cause it to not turn/start.
In all my experience the only main issues I have had with occassional stragglers is a fuel contamination problem, clean it up and should work good for a long time.
SOURCE: Yard Machines - Won't shift into gear
The problem most likely is the shaft on which the interlock slides back and forth on inside the transmission. The yardmachines have a continous spinning shaft which ends in a bevel gear. The is an interlock plate which is connected to the Forward Reverse shift lever, this plate slides back and forth and either engages the forward gear or the backward gear. This shaft is most likely galled up, preventing everything from sliding the way it needs to. This is not a difficult thing to fix if you are somewhat mechanical. Disassemble the transmission and check if everything slides
Posted on Jun 01, 2009
SOURCE: "how do i change the primer bulb on my yard machine lawn mower"
You should be able to remove the old one with a screw driver or needle nose pliers. The new one should have a new gasket with it.
Posted on Jun 19, 2009
SOURCE: GOT GASOLINE IN OIL TANK.
Empty the tank of the tainted gasoline (Maybe add the right amount of oil and use it for a trimmer, etc), fill tank with fresh gas and clean the spark plug, since it is probably fouled out. You may have to clean the carb with some carb cleaner, and clean your plug a few extra times, but it should be fine. Hope this helps. Good luck.
Posted on Jul 15, 2009
SOURCE: lawn mower keeps dying
Remove gas cap. If mower now runs without stalling, your problem is the vent in the gas cap is blocked. Replace the cap. Common problem!
Posted on Sep 22, 2009
Jul 04, 2013 | Garden
Feb 02, 2013 | Garden
May 29, 2012 | Mtd 22" Yard Machine Push Mower
Sep 14, 2011 | Yard Machines 155 Torque Briggs Stratton...
Aug 13, 2011 | Mtd 22" Yard Machine Push Mower
Jun 30, 2011 | Yard Machines 155 Torque Briggs Stratton...
May 02, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
Jan 28, 2010 | Mtd 22" Yard Machine Push Mower
Mar 01, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
3,779 people viewed this question
