My name is Becky. I work at Qwest communications and I have a customer that is wanting to use her Encore modem with our broadband. I am showing the broadband is set up, but I do not know how to help the customer to program the modem. Her modem was working before with a different provider. So I am assuming that she has already installed the drivers. Can you help me with this?
A Router(which can include a Modem as part of it) has an IP address. Opening a Browser at that address will get its Login page up. Logging in will show its MENU / Up time/ main page where you set it up. eg type in your new ISP details / Login username password. the long number you quote is NOT a name of a router model(it a MAC address of a Pro-Nets product). you can look here for an example login for one of their products a WR850RD but have no clue what actual product you have.. "https://www.cleancss.com/router-default/PRO-NETS/WR850RD" which some kind techy person will show the IP address and login details for you. However they are usually written on the LABEL stuck to the ROUTER.
SOURCE: access home network remotely via zyxel modem
you will not be able to access from one network to another even if you are on the same workgroup. However, you can setup VPN on both side. the other is to use commercial remote software. i.e.: vnc, mypc, teamviewer, etc.... they don't need anything else, but do require setup on both machine. This is much easier, don't need any permission from the network administrator, or company permission.
SOURCE: connecting a thomson speedtouch 858v6 modem to wireless
open the web browser, type in "10.0.0.138" without the quote in the address bar, press enter. that should bring you the the log in screen of the speed touch.
type in "admin" with password of "SpeedTouch" S and T are capped.
to configure the DSL go to the following link and select the configuration you are look for.
http://www.grandecom.net/site-file.php?fid=37
SOURCE: How to install zte 831 aii Broadband modem in Linux with USB
I was working at one of Lithuanian internet service providers. We often had clients complaining about ZTE 831 connecting through USB. The answer is - use a LAN card. Sorry.
SOURCE: adsl modem giving very slow and intermittent internet connection
this is not a problem with ur PC or router this could be in the Filter or splitter that ur ISP gave you, what i would do is call ur ISP and have them run a line test that could be the reason
i work for att. and that does happen ALOT you can also go to
www.speakeasy.net go to the bottom you should see whats my speed or test ur speed click on that and select a server closest to you and it will run a speed test up and download speed
good luck ,
July
SOURCE: settings saved do not match requirements on this computer
Go into network connections on the laptop and select the Wireless Network. Go into properties and find the TCP/IP settings and ensure that the IP address setting is set to Automatic and the DNS settings also. If you have wireless security set on the router you will have to set that up on the laptop as well.
